Home > My Defender > Rebuild of "Derek" 1989 Ninety
Page 2 of 14 <123 ... 121314>
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
More work continues...
... we took out the entire wiring loom, steering column and foot pedals, then came removing the bulkhead which was the last piece of bodywork to come off.
Any advice on what to do with it now and who can do the work would be much appreciated please.
Our thoughts are that it needs a bit of welding here and there, shot blasting and then probably galvanising. is that correct?
Can you successfully spay paint on to treated galv and expect it to adhere properly? Alistair at Richards Chassis said his advice was not to paint the new galv chassis. Car manufactures do these days don't they?
Questions questions - thanks for the answers. Thumbs Up Thumbs Up Thumbs Up
Hope you enjoy the progress;
Post #643142 11th Aug 2017 9:53am
L110CDL
Great work so far Thumbs Up Clayton.
Keeper.
Post #643750 13th Aug 2017 10:08pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
To try to answer your questions -
Media blast or chemical strip to remove paint and rust. Weld areas which need it. Galvanising can be a bit hit and miss, sometimes the part comes back ok other times (depending on who's doing it) parts can come back a mess. I have galvanised bulkheads before and its worth speaking with the galvanisers explaining what your expectations are. Due to the metal being quite thin in places such as the foot wells it can warp.
Galvanised metal can be painted but needs to be treated with mordant solution first which will give the paint a good key.
Post #643793 14th Aug 2017 7:46am
HK07
Post #643826 14th Aug 2017 10:38am
Procta
coming a long there! Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #643865 14th Aug 2017 12:53pm
HK07
Hk07
So work carry's on on this little beauty...
Engine & gearbox out or off whichever it is.
Just left with the running gear, we are now waiting for the new chassis, all the bits taken off of under going a refurb and a nice fresh coat of paint ready for the reassembly
Bulkhead has been of to a great chap who has made an amazing job of the welding repairs, its now in great shape soon to be off for galvanising.
Battery box is in a sorry state, not sure what to do with that yet, any advice?
Cappings all removed and welded ready for the galvy treatment al well.
Why are the cappings different from Landrover to Landrover?
On my Puma they're all one piece of metal, on this one they were in 3 bits each two welded together at the front, and on others they are in three bit but all welding together?
Strange, but I wanted them welded to offer greater strength to the back of the tub.
Post #645451 21st Aug 2017 4:07pm
V8GPC
YRM metal supplies sell a flat pack battery box - not done one myself but looks good.
https://yrmit.co.uk/product/battery-box-2m...-defender/
Post #645469 21st Aug 2017 5:29pm
HK07
Now it is mostly striped, attention has been turned to cleaning, rubbing down, treating and recoating all the little bits off the car. This has all been done by my father.
Post #646426 26th Aug 2017 1:25pm
HK07
With all that going on I have been working on all the steel parts of the bodywork that needed shot blasting in preparation for galvanising;
Off to be shot!
Back from the blaster, but need to be kept dry so neatly perched in my lounge!!!
The shot blasting process has shown a couple of further area's of rot in the bulkhead that we weren't aware of, so next week a bit more welding required. It was a shame to see the damage, but much better to know of it now and deal with it with ease Thumbs Up
Post #646429 26th Aug 2017 1:38pm
HK07
Yesterday the old rusty chassis rolled for the last time.
Back axle off
Front axle off
It will rest here until the new one arrives, hopefully next week, and we can be sure we don't need any of the old bits.
The rear cross member was new a couple of years ago and is in very good shape. I will cut that off and sell it.
Post #646431 26th Aug 2017 1:50pm
HK07
During the process of dismantling we have come up with a design modification that we think will much improve radial arm bush wear.
See what you think Rolling with laughter Rolling with laughter Rolling with laughter
Post #646433 26th Aug 2017 1:57pm
HK07
A high powered pressure washer and a bottle of GUNK certainly make short work of 30 year of grease, grime and mud!
From this;
To this;
and these;
Post #646435 26th Aug 2017 2:13pm
HK07
Thanks for that Thumbs Up Thumbs Up Thumbs Up
Post #646436 26th Aug 2017 2:16pm
Dieselhead
Enjoying your project so far Thumbs Up
I have a 90 which I wish to transform into the same thing which your planning & have started gathering in a few parts even though I dont know when I will start it yet Crying or Very sad Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #646473 26th Aug 2017 7:32pm
L110CDL
^^^^ Whistle Wink Clayton.
Keeper.
Post #646827 28th Aug 2017 8:45pm
