Home > Maintenance & Modifications > Picture request please - OME suspension on a 110
AJC
I could do with a suspension upgrade. When towing trailer or fully loaded up for a weekends camping. It sits a bit low. I don't want to go silly high. Has anyone got experience of the OME kits.
I have driven a D1 on HD terrafirma kit and hated it, but liked the medium duty kit on my old D1. Any suggestions please? Thanks
Post #645513 21st Aug 2017 8:21pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I don't have any experience with them but I don't think i've ever heard anyone say anything bad about OME
110 is looking very nice by the way 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #645524 21st Aug 2017 8:35pm
Cupboard
Just a thought, if you're still on stock suspension have you got the brown and purple springs or the green and white springs?
The standard ones are colour coded from the factory with some dobs of paint on each spring, white and green being lighter duty than brown and purple. If you have the white and green ones then an easy and cheap upgrade would be to the brown and purple. The stiffer ones were fitted to some station wagons and the utility Defenders.
My hardtop came with the purple and brown ones as default, and I've just changed to the green and white ones because even when I was loaded up for camping they were still too hard. I seem to be able to go away with enough supplies for 3 weeks and still have a lighter Defender than most people going away for a weekend Very Happy
Post #645525 21st Aug 2017 8:37pm
rallysteve
Have a look at this post. I added a photo of my 110 with OME fronts:
http://www.defender2.net/forum/topic52032.html
Hope that helps,
Post #645543 21st Aug 2017 9:05pm
L110CDL
Standard springs front and with the standard brown and purple on the back, hope this helps Thumbs Up
Unloaded
Loaded with about 600-700 Kg's
Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #645568 21st Aug 2017 10:30pm
agentmulder
Kuwait
I have a 110 and with roof tent, roll cage, winch bumper and winch it was looking a bit low:
I got the rear OME2754 and front DA8924 sets and here you see it much higher with roof tent not on:
Most obvious on the front.
When installing them the jacks made it such that the axles were well and truly fully articulated - in this state the standard shocks appeared to be ok and handling the full compression/extension. I'm about 80% sure I removed the anti roll bars to get in this state also. Solved the bowel problem, working on the consonants...
Post #645573 21st Aug 2017 11:30pm
JeremyJ
OME springs, shocks and blue Polybushes. Works perfectly in my opinion!
Post #645585 22nd Aug 2017 6:32am
AJC
That looks perfect in my opinion, perfect height. What spec where your springs please? Thanks
Post #645603 22nd Aug 2017 7:36am
JOW240725
All lovely 110's! Thumbs Up James
Instagram @suffolk_rovers
Post #645642 22nd Aug 2017 11:01am
Cupboard
When I changed my springs I couldn't get anything like the full droop with my stock shock absorbers, they were definitely the limiting factor. I had to take the shocks off to get the springs out.
The first side I tried to do just using spring compressors and I couldn't. The second side I started by taking the shock off and didn't need the spring compressors.
Post #645714 22nd Aug 2017 7:11pm
agentmulder
Kuwait
Well, I was under a time pressure to get it done so i's entirely possible I didn't take full stock of the axle situation in the process - but in saying that I do recall the moment where I thought 'this is working', but not the details...
I'm happy for now, if I do remove the ARBs I'll revisit it all. (Hopefully by then I'll have new shocks anyway 🤗) Solved the bowel problem, working on the consonants...
Post #645721 22nd Aug 2017 7:18pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
I'm running OME 2767 front springs with 60037 shocks and OME 2755 rear springs with 60039 shocks.
The lift was about 1 inch (ish) It levelled out the overall height as it was always sitting too high in the back end. Ride is excellent both empty, and when all geared up. (have a fairly heavy front bumper, often have the roof top tent on back, plus a fridge and assorted gear)
I had the OME set up on my NAS 90 for 12 years, no issues, (yes, the shocks actually lasted that long). I highly recommend the OME set up.
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #645758 22nd Aug 2017 9:08pm
Mine was all OME, I had a +1" on the front to level it off. I rang Derrick at LRS, told him what I was using the 110 for, no winch etc and he specced it up.
Post #645794 23rd Aug 2017 5:44am
Kit
Too many nice 110s Bow down 1993 200 Tdi 90 CSW
Post #645810 23rd Aug 2017 7:00am
AJC
This is the kit that I'm looking at, which is what CDN has
https://www.flatdoguk.com/defender-110-hd-...-load~1524
Post #645817 23rd Aug 2017 7:20am
