Home > Puma (Tdci) > Puma overheating |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
None - have you air con, a bar, winch or spotlights or is the radiator clear? Mike
21st Jan 2009 9:12am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Stuck rad'stat ? 2.4 90 XS
21st Jan 2009 9:24am |
ah'you've checked that, expansion tank cap vent. 2.4 90 XS
21st Jan 2009 9:26am |
Daniel TD5 Member Since: 22 Jul 2007 Location: london Posts: 97 |
this one got a tad hot
http://cgi.ebay.co.uk/fire-damaged-land-ro...240%3A1318 dan |
21st Jan 2009 1:57pm |
Yes - looks a little like a fire though Mike
21st Jan 2009 2:13pm |
No Mike,thats the new charcoal interior 2.4 90 XS
21st Jan 2009 2:17pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Thats what mines going to look like if LR don't get their finger out
21st Jan 2009 2:22pm |
looks like the sun roof leaks
21st Jan 2009 2:26pm |
a way of charging more...i see Mike |
21st Jan 2009 2:31pm |
islu51 Member Since: 08 Mar 2008 Location: Cirencester Posts: 3 |
Will,
Can you give us more details on the overheating and we will try to help you. have you checked that the system is still under pressure? Is the expansion tank or cap seal damaged? Is there any circulation or collasped hose? How quickly does it overheat and under what driving conditions? |
21st Jan 2009 3:13pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Back wheel looks good NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
21st Jan 2009 4:41pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Turbo should be OK as it's under the heat shield
22nd Jan 2009 5:43pm |
Will Member Since: 20 Jan 2009 Location: Tanzania Posts: 3 |
I was hoping someone had come across similar problems. The cap seemed faulty as no pressure, so I sealed it with plastic and it still overheated. I could do with a cooling system diagram as it seems pretty complicated. It is overheating after 15 mins. Ive exhausted my ideas.
23rd Jan 2009 5:06pm |
Will,you say you think the caps at fault have you tried another one. 2.4 90 XS
23rd Jan 2009 5:25pm |
