Home > V8 > V8 ENGINE MODS AND EXHAUST
ami1971
Hi, guys, just on with doing my 110, V8 - what sort of mods can i do to make it sound beefy, also is their any one doing a SS exhaust system for it??
Post #599261 5th Feb 2017 3:02pm
Rimmers do stainless sports exhausts.
Post #599273 5th Feb 2017 3:32pm
nicam
2015 Defender 110 Puma 2.2 USW Aintree Green
Put the full SS system including tube headers on my V8 90 and the difference it made was amazing - it would pull a gear higher in most situations. I put it down to the restrictive original manifolds mostly.
Well worth it! Don`t drive faster than your angel can fly!
Post #604302 23rd Feb 2017 8:11pm
Pickles
A set of headers to start with, and then a free flowing big bore exhaust, if you're going the single pipe way, 2.5" should do the trick.
HOWEVER, and from the land of V8s, I don't see many of you guys doing this, the "classic" V8 exhaust is twin pipes, coming out either side of the rear of the vehicle.
Pickles.
Post #604358 23rd Feb 2017 9:22pm
VVS210
Janspeed...
Very Happy
Tubular headers & big bore performance exhaust.
Post #604367 23rd Feb 2017 9:40pm
Blanc
Has anyone here who has fitted tubular headers also installed heat wrap on them?
I've just fitted some (Rimmer Bros) and am worrying about heat.
Thanks
David
Post #606237 2nd Mar 2017 9:51pm
Kernow90
United Kingdom 1990 Defender 90 V8 Petrol CSW Alpine White
I've got stainless tubular on mine and don't get any problem with heat , just beneath of where your starter motor cable runs that's all
Post #638976 22nd Jul 2017 10:00am
I wrapped mine. But I'm going to add more vents to the bonnet when the v8 comes off the road in Autumn.
Post #639008 22nd Jul 2017 3:54pm
Romadog
My 110 with Gems V8 has a 50th Anniversary y section with CATS, then a 300tdi Centre silencer Removal pipe and 300tdi 110 rear section. So only silencer is on the tailpipe.
Works well Thumbs Up
Post #639017 22nd Jul 2017 5:08pm
need4speed
Sorry but I really need to weigh in here.
Most of the tubular manifolds available off the shelf for the RV8 are absolutely terrible. Mainly because most were actually designed for sports cars that want most of the power gain at higher rpm. Hence the 4 into 1 design.
The only ones worth considering are specifically designed manifolds that put the power where you want it on a defender i.e. Low to mid range rpm. This requires manifolds that are 4 into 2 into 1.
In reality the cast twin-port disco v8 manifolds are very good indeed. 4.6 RV8 110HT
Post #641671 3rd Aug 2017 5:20pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
John Eales has the ported cast manifolds back in stock according to my knowledge but I guess pricewise they are not justifiable on a non race engine... What ever manifolds you get have them ceramic coated instead of wrapped. Wrapping can burn if you got a heavy oil spill. m
Post #642111 5th Aug 2017 9:47pm
oneten110
For what it is worth I had a double s system on mine and it was an absolute pile of junk. It is not intended for the 110 but for a range rover. Thus there is an additional section of pipe between the Y pipe and centre box which was continually working loose, the tubular manifolds were a dreadful fit on the heads, a poor fit on the Y pipe and the welds on one of them cracked. The tail pipe came out right where the rear mud flap is fitted and they weren't even remotely interested in doing anything to remedy the situation.
Currently I am running Range Rover cast manifolds, Range Rover 2-1 pipes, a Range Rover Y pipe, 300 Tdi middle box and a plain tail pipe without the resonator. Sounds nice without being gobshyte loud
Post #645214 20th Aug 2017 2:03pm
