Home > Td5 > Engine type on VIN number
Davidarnol
United Kingdom 1995 Defender 90 300 Tdi HT Epsom Green
Had a look at the VIN number of my 02 MY DEFENDER, normally a TD5 engine would be shown as the number 8 on the Vin code (also the 8th character along the VIN code) my VIN shows a number 5 which does not match with any Landrover engines on the VIN decoders, any ideas why this is, it certainly looks like a 15P TD5 engine!
Post #644678 17th Aug 2017 1:21pm
dorsetsmith
vin pos 1-3 SAL=Solihull England
vin pos 4-5 DH = DEF 110
DV= DEF 90
vin pos 6 body type A= 2 door pick up , HT
vin pos 7 engine type
vin pos 8 Gear box type 7 = 5 speed Manual i.e. R380
Certainly looks like a 15P TD5 engine! 2002 defender will fitted with 15P engine at LR
Post #644700 17th Aug 2017 3:14pm
Davidarnol
My vin is -
SAL - as above
LD - Def 110
B - Defender heavy duty
A - hard top
5 - engine type ???
7 - R380 RH gearbox
2 - model year 2002
Etc, etc, etc
Or am I getting it wrong?
Post #644711 17th Aug 2017 3:41pm
dorsetsmith
if your vin shown 5 for engine type both my engines are 15p and vin shown 5 under engine type
Post #644712 17th Aug 2017 3:46pm
NickEJ
Slovenia 2004 Defender 90 Td5 XS CSW Galway Green
Try taking the acoustic cover off to see if you still have a paper label on top of the engine. Mine's still there and it will definitively give you the engine type.
Post #644767 17th Aug 2017 8:55pm
dorsetsmith
Or engine number is on the left hand side of the engine (turbo side) about half way along the block below the exhaust manufold. It's almost inline (just infornt) with the pipe from the breather from the rocker cover to the turbo inlet hose. It's about halfway down the block.
Post #644832 18th Aug 2017 8:50am
Djcla
Hpi check should give you engine number and it tells you if it's 15p at least the total car check app I use does. This was you don't even need to get up lol
Post #645687 22nd Aug 2017 4:19pm
