Home > Maintenance & Modifications > Windscreen rubber replacement |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20563 |
Typically best to replace both in case there were any weaknesses.
Remember there are different glass types and brands with varying quality. Genuine would not be cheap, cheap is not always good. KEEP CALM AND Drill ON đŹđ§đ´ó §ó ˘ó Ľó Žó §ó żđ´ó §ó ˘ó ˇó Źó łó żđ´ó §ó ˘ó łó Łó ´ó żđŽđŞđşđ¸â˝ď¸đ˘ď¸âď¸đ§°đŞ |
16th Aug 2017 5:21pm |
I've been led to believe the aftermarket rubber seals are too fat and you risk cracking the glass when fitting them. So make sure you get an assurance from the fitter that if they glass gets broken while refitting he'll replace the glass at his own expense.
Cheap screens can end up with optical flaws in them, they're horrible. Ł32 is probably a standard non tinted, non heated screen. It'll be more if yours is heated, it would be daft not to fit a tinted one even if yours wasn't originally. They take the edge off the heat on a sunny day. |
16th Aug 2017 5:39pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
That sounds too cheap to me? EDIT: Didn't realize how cheap the non-heated/non-LR windscreens are! 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top Last edited by Kit on 16th Aug 2017 5:49pm. Edited 1 time in total |
16th Aug 2017 5:45pm |
Chris90V8 Member Since: 02 Oct 2016 Location: Suffolk Posts: 714 |
Been quoted Ł50 for a genuine rubber seal đ. ...... . .... . .. đđđđđđđđ
16th Aug 2017 5:47pm |
Peaknocker Member Since: 14 Apr 2017 Location: North Yorkshire Posts: 138 |
That's cheap, I paid nearly Ł100 for the genuine windscreen rubber Mike
16th Aug 2017 5:50pm |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
Nothing wrong with Bearmach rubbers , I put mine in bucket of boiling water before fitting,
16th Aug 2017 7:02pm |
AVB Member Since: 04 Jul 2016 Location: Herts Posts: 15 |
Job Done. I went for replacement screen as there was a chip in the original that I hadn't spotted. The new screen is from Pilkington and I went for a tinted one for Ł38. Total fitted price with new rubber was Ł108. So I don't know what would have been better for Autoglass to quote Ł300.
17th Aug 2017 5:02pm |
Did you do it yourself? KEEP CALM AND Drill ON
17th Aug 2017 5:03pm |
You don't know me do you? No I would not attempt anything as complicated as that! The price was fitted.
17th Aug 2017 5:09pm |
