Home > Puma (Tdci) > water getting in
inthedesert
water getting in
Hi all, my 2008 hardtop is going back to the dealer to try to solve where the water is getting in. As the dealer has failed to solve this I would like to ask for some advise. The water seems to collect in the roof liner and runs down from the top of both front doors when cornering (roundabouts are a favourite).
Also, the warranty is due to run out soon. Is there anything else I should ask them to look at?
Many thanks.
Post #62614 7th Mar 2011 12:17pm
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Its not condensation building up between headlining and roof is it, and running down?
My hardtop is only basic spec so only headlining in front section i.e. not over loadspace, but the amount of condensation that appears in the back is sometimes unbelievable. It almost rains in the back of mine during the winter, meaning anything in there needs covering over, to stop it getting wet!!!
Post #62673 7th Mar 2011 6:52pm
JSG
At a guess, the water could be getting in through;
Alpine windows seals,
Sunroof (if you have one) seal,
Cracks in the rain gutter around the roof,
The roof seams.
I have the same in the 90 and have narrowed it down to the roof seam.
There is a water ingress manual about on the web that tells you where to look. John
2011 Tdci 110 CSW XS
Post #62686 7th Mar 2011 8:08pm
holmessato
2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I only get water in the footwells on the passenger side front. After close inspection today I am alarmed to find rust bubbles already forming on the bulkhead under the windscreen to bulkhead seal near the reinforcement bracket. Its still under warantee, but do I trust the dealer to replace this seal without adding further leaks? Question
Post #62705 7th Mar 2011 10:42pm
inthedesert
thanks, I'll have a look today. I can't rule out condensation as it has been pretty bad in the back.
Post #62725 8th Mar 2011 7:36am
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i'd say Matt's probably right as series land roves where known for that, saying that it is a defender and it could very well be tracking its way UP from the screen wash for all we know Razz
good look with sorting it
Post #62738 8th Mar 2011 8:49am
Lorryman100
Also check that the Heater air intake teets are not blocked. There are two of them and if blocked the heater intake will fill with water and leak into the passenger footwell. Took me ages trying to find where the water was coming from, in the end I found it was blocked teets.
You can see the part of the heater intake grill (left wing top) in the bottom right of the picture to give you orientation. There are two draining teets arrowed red.
Post #62760 8th Mar 2011 10:46am
stevie
My double cab had the same problem with water getting in through the roof. The problem was the sealant had cracked in the roof joints. They had to re- seal the roof joints and repaint all the roof. Cured the problem. The joints had cracked the worst on the curve of the roof but also had a crack in the middle of the roof joint.
Post #62810 8th Mar 2011 6:30pm
also check the top of the windscreen joint, this was bad on my td5, once sealed desert like Smile
Post #62822 8th Mar 2011 7:34pm
KarlB
Australia 2010 Defender 90 Puma 2.4 XS CSW Rimini Red
I have a copy (pdf file) of the water ingress manual. Anyone who wants a copy send me a PM with your email address and its your.
KarlB
Post #62879 9th Mar 2011 2:25am
inthedesert
Thanks for the help.
I have spent a hour going over the possible causes as highlighted, but I can't see anything obvious. The door seal is wet on the inside near the roof liner and I think there is too much for condensation.
I'll take it in and give them some pictures as evidence. It's in next week so I'll report back.
Post #62969 9th Mar 2011 6:01pm
Grockle
thanks Brian, I hadn't noticed the l/h teet Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #63044 10th Mar 2011 4:20am
Eduardo
Maybe this file can be useful
https://www.defender2.net/gallery/albums/u...cedure.pdf
Cheers Eduardo
Post #63103 10th Mar 2011 12:57pm
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
I had the windscreen seal replaced. problem solved. 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #63958 16th Mar 2011 4:52pm
inthedesert
Firstly, thanks for all the help. The 'Leak procedure' was very helpful.
I droppped the truck in early on Monday and gave them both leak pdf documents and some photographs. I collected it on Wednesday evening.
They have filled the windscreen hinges, the roof seams, the front corner seams and the drain channel seams at the top.
Fingers crossed now.
Post #64422 20th Mar 2011 1:13pm
