Home > Td5 > Rear Driving Member Bolts snapped |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 |
I recently noticed that my rear wheel was leaking grease. Upon removing the wheel all the bolts on the drive member were broken off. What could have caused this?
4th Aug 2017 9:26pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2947 |
Loose bolts
4th Aug 2017 9:30pm |
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 59 |
I like to check these every 20,000km, as they can work loose. I have found them to remain tight if I have spring washers under the bolt heads. Important to torque them up using a tension wrench to avoid overtightening & stretching of the threads.
Cheers, Lionel |
9th Aug 2017 2:01am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17478 |
Worth bearing in mind that these are supposed to be grade 10.9 HT, not the more common 8.8 HT. If someone has at some time replaced the original bolts with 8.8s, it might explain your situation.
9th Aug 2017 10:11am |
Very good point, blackwolf!
Cheers, Lionel |
10th Aug 2017 1:38am |
The easy solution:-
Click image to enlarge Socket head caps, which are grade 10.9 as standard, with spring washers not thread lock, and in holes that are scrupulously clean. |
10th Aug 2017 7:29am |
Thanks everyone!
12th Aug 2017 4:27am |
