Home > Technical > Removing wipac leds
Rad666
United Kingdom 1998 Defender 110 300 Tdi DCPU Keswick Green
Removing wipac leds
How do you remove the screw cap covers from the wipac reverse and rear fog light? Ive tried a small screw driver etc and they arnt budging ☹️
Post #639501 24th Jul 2017 9:23pm
Sockpuppet
I thought all lights you removed the bulbs from the back?
All the Wipac LED fittings I've seen are IP67 sealed so no bueno if you're trying to open them.
Post #643281 11th Aug 2017 9:01pm
The OP is talking about LED's and not Incabdescent.
You are correct, they are sealed but the OP means the screw area caps on some models.
I have them on mine on my fog and reverse.
Carefully using a knife blade or similar should prise it out.
Use safety glasses whist your at it and maybe masking tape to avoid marks.
The caps aren't really needed, but the are purely fir asthetic reasons. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #643293 11th Aug 2017 9:26pm
zsd-puma
or drill a small hole into the cap, screw a self tapper into it and pull it out. They're not really needed.
Post #643346 12th Aug 2017 2:07am
Yep, good idea. Of course the caps are no good after though.
Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #643381 12th Aug 2017 10:00am
AJC
Use a proper pick set to get behind them. That's all I did
Post #643554 13th Aug 2017 6:39am
