![]() | Home > Technical > 110 milometer / odometer fix |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
Sounds like the speedo drive is ok; as it turn the trip, and registers speed.
so likely to be a fault with the speedo itself. (internal) 170,000 and how many unrecorded miles ![]() You may be better finding a second hand unit on ebay; its a really easy swap You can take the speedo apart, but at 170,000 likely to have warn out or damaged a small cog or something. The mileage now is irrelavent; you could set the replacement speedo; or just record the mileage change. Its not illegal to display any mileage, or even reset to zero; it only becomes illegal if you tried to defraud someone by suggesting the mileage is lower than stated. But as you bought it knowing it was a high mile..r and are happy with your choice, its only a number This one is almost spot on for miles too http://www.ebay.co.uk/itm/Land-Rover-Defen...Sw-89ZTC~p Then sell yours backon ebay as spares or repair; you make get something for it. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2708 ![]() ![]() |
170,000 miles is not high miles for a 1994 110, indeed quite the opposite.
It's quite common for mechanical speedos to get stuck when ticking over to higher numbers as they age. There are a number of companies who will be able to repair it for you (Google 'mechanical speedo repair' or similar), or you could prise the cover off and have a go yourself. Alternatively upgrade to a Td5 speedo which has an electronic mileage readout. |
Docyo Member Since: 16 Sep 2016 Location: Belfast Posts: 27 ![]() ![]() |
The mechanical swap seems reasonably straight
forward and I would certainly give it a go. Would the digital display swap be as easy ? |
explains all you'd need to know about going digital
http://www.retroanaconda.com/landrover/200...tdi300tdi/ |
Thanks. Just had a look. Mechanical it is. Wanted to keep it original anyway !!
Ok - basic question. How do I remove the three plastic attachments at the back of the milometer so I can remove it ?
Got it out. Didn't realise if involved brute force. Now how do I dismantle the speedo to get at the mileage gauge !
![]() Click image to enlarge ![]() Click image to enlarge |
I don't want to sound rude, but if you have to ask that then maybe you'd be best getting someone to do it for you or buying a second hand one that works. Ray
Maybe so. But do you have an answer.
I'd start with the two bolts on the back, but I've never pulled one apart before Ray
Thanks
you have to remove the bezel, that's the only way.
Its crimped over and sandwiches the glass to the can. You can to go around the whole lot 360 and with a small screw driver bend back the edge of the bezel. It won't look factory once you get it apart, and to put it back involves the same. A proper company who repair them replace the bezel with new and have a special gig that crimps it closed. You can get a decent close by hand, and its not viewable in situe. So its your call. |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
Or you could buy this off me for £85.00 plus postage or can collect in person.
Land Rover defender 90/110 200/ 300 TDI Instrument panel complete , Speedo, Fuel gauge, water temp, clock and warning panel, as seen in good condition ![]() Click image to enlarge For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Thought that might be the solution but didn't want to start working at it in case there was a simpler way. Obviously would never look the same again ! Thanks for the answer.
