Home > Technical > Central locking fob playing up
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
I'm having problems with the central locking fob, as time has gone by it has got weaker and weaker, I am now standing right next to thr drivers door and onlt then after about 10 presses does it unlock Big Cry same applies with the spare as both are very well used.... unless someone can come up with a fix (fitted new batteries, no joy) I'm gonna have to buy a new one, has anyone bought from here :
https://www.jgs4x4.co.uk/land-rover-defend...g-key-fob/
and programmed it yourself? can it be done with a Nanocom Evo?
Thanks in advance Thumbs Up
MIke Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #642492 7th Aug 2017 9:53pm
bear100
There is a thread on here explaining how to extend the range by extending the aerial cable Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #642494 7th Aug 2017 9:59pm
taffrican
cheers Bear, I read the thread and will be looking into it tomorrow Thumbs Up Optimists say the glass is half full..
Post #643085 10th Aug 2017 11:46pm
Smithy
I used to have the same on my Puma.
All you do is hold the fob against your scull and activate the fob.
It seems the body fluids boost the signal and activates the central locking 10' away.
Post #649728 12th Sep 2017 2:12am
^^ But what does it do to your brain? Shocked
Post #649754 12th Sep 2017 7:28am
zsd-puma
That trick works with any fob. It uses your skelton as an antenna, but you shouldn't need to do it unless the battery is very flat.
In the Defender the antenna lead in the car is poorly routed or not long enough. My mini's plips have a much better range, and they're the same plips.
Post #649778 12th Sep 2017 9:10am
taffrican
Thanks for the input chaps, I went down the route of extending the grey/orange antenna wire and it has improved a bit, at least now I can unlock the car from around 5m away 👍🏻 Optimists say the glass is half full..
Post #649830 12th Sep 2017 1:12pm
