Home > In Car Electronics > Subwoofer extension cable |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2108 |
Hi all
I have just added the under cubby heater box and heater, which all was fine, except that I have a factory fitted Alpine-branded Hi Line 150W low profile subwoofer on the back of the cubby box which has a bit of a stretch on the cable that is routed from the middle of the plate under the cubby. Do you know where I can get an extension cable to allow the cable to be routed better with less stress... I looked at cutting the cable and fitting longer wires but I don't trust my soldering skills !! Click image to enlarge Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
10th Aug 2017 10:11am |
Take it to an auto electrician to extend the cable, he should have all the correct coloured wires and you know the job is done properly. I don't think anywhere does an extension. Ray
10th Aug 2017 10:24am |
^^^^ .... living in the paradise of remote north cornwall that may prove to be an adventure !!
It is an option and may be the route I'll have to take, but looking for a KISS approach first Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
10th Aug 2017 10:48am |
Could you drill a new hole in a more useful position in the plate under the cubby to give you a bit more flexibility? Darren
10th Aug 2017 11:32am |
Sadly not - I looked at doing this first, however the new 'under cubby heater box and heater' raise the cubby box up about 4 inches, and position the Woofer higher and further back than its original location so requiring the cable to be moved from the centre of the old under cubby plate to the side then feed round the underside of the new plate to reach the woofer... Click image to enlarge
Tom, looked at that too as an option but this is a simple fix if there is a cable available and more likely to last longer than my attempt of soldering and then burying the cable under the new heater and associated fittings ! - it may still be the best option but not my most favoured! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
10th Aug 2017 11:55am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20355 |
See if the plug has any identification on it.
You may be able to get male and female versions and make your own extension loom. Without having to cut the standard loom. It's common enough to do for relocation and leaves OE harnesses in-tact as factory fit. $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
10th Aug 2017 1:30pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Drop PaulMc a line and see if he has IDd it 1988 90 Td5 NAS soft top
2015 D90 XS SW |
10th Aug 2017 1:54pm |
^^^^ My thoughts too. Its not one I recognise off the top of my head but I'm damn sure there is likely something in the market that mates with it. $W33T $0U7H3RN $UG4R
10th Aug 2017 2:27pm |
Cool ! I’ll take a proper picture of it when I get home again and see what he thinks .. meanwhile the tame electrical person on my platform is going to give me a crash course on crimping and then setting me up to cut out the connector block all together and use bullet connectors, heat shrink and have as long a lead as needed, with out the possibility of me melting the thing !!
so something to try and a new skill to learn - rather than my ‘bodging’ squash and hope that I do at the moment ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
10th Aug 2017 3:59pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 501 |
The connector is from the Yazaki YESC Kaizen series. The male connector is available from Land Rover, without terminals, as YPC804550 The female connector is not available from Land Rover. I have both the male and female connectors with terminals, and could make an extension cable. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
10th Aug 2017 5:27pm |
^^^ Wooohoooooo !!!
do you have a possible round about cost of an extension that is about 18 inches long ... ??? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
10th Aug 2017 6:12pm |
Nice one Paul. $W33T $0U7H3RN $UG4R
10th Aug 2017 6:23pm |
CarlinAbz Member Since: 15 Sep 2013 Location: Aberdeenshire Posts: 76 |
I am also interested in an extension cable as looking to install the same cubby box. Apologies if you were doing someone a favour.....but if you are making them can you give me an idea of cost? Many thanks Carl.
22nd Sep 2017 7:52pm |
Hi Carl
Sadly I was unsuccessful in finding an extension cable So am now going to extend each cable individually by about a foot, and use crimp joints on the lower cable to the connection and feed it though a new hole that I will drill into the bottom pate of the heater. Ill let you know how I get on (wish me luck!) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
22nd Sep 2017 8:31pm |
