Home > Td5 > Front mud flaps help |
Farmer58za Member Since: 20 Jan 2017 Location: Worcestershire Posts: 85 |
You can get a new single mudflap with bracket for under £20 off Ebay.
Those bits of thread sticking out are probably the remains of the broken M6 bolts that held the original mudflap in place. Those bolts are screwed into 'rivnut" threaded inserts. If you are lucky, you will be able to grab the end of the threads with a vise-grip then turn the old bolt shank out. If the old bolts are seized in then the best thing to do is to drift the old rivnuts through into the chassis and install new inserts before installing the mudflap. Regards Dave's not here man... |
30th Jul 2017 6:34pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
So how would you install the new insert ?
Is this an insert in M6 I'd need ? Do they just tap in? http://m.ebay.co.uk/itm/RIVNUTS-NUTSERTS-R...1388153801 |
30th Jul 2017 7:12pm |
NickEJ Member Since: 24 Nov 2012 Location: Ljubljana Posts: 152 |
I drilled out the rivnuts and put some meatier bolts on mine.
30th Jul 2017 8:51pm |
Cheers just debating OEM versed aftermarket as I don't want to fine aftermarket doesn't colour match the other side
30th Jul 2017 9:22pm |
Yes, those are the nutserts (rivnuts)
You can set them with a tool, just like a pop riveter, like this: http://www.ebay.co.uk/itm/4-8mm-THREADED-R...xyldpR~66a Dave's not here man... |
30th Jul 2017 9:44pm |
I've done M6's, 8's and even 10's following this You Tube tip.
Wouldn't want to do too many 10's though but fine for smaller sizes. |
30th Jul 2017 10:29pm |
Thanks for replies so if I need to remove old rivnut what's the best way? Lol this is a lot of research just to change a mudflap
31st Jul 2017 6:37am |
Drill it out and replace with a nut and bolt.
31st Jul 2017 7:23am |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
they are soft enough to punch into the chassis with a hammer and punch, much easier than drilling upside down and don't damage the hole; real easy one tap too.
Also the outriggers have a hole just big enough to get your hand inside to retrieve. I used stainless bolts, penny washers and a nut. Reached inside dropped the bolt down a penny washer; and then washer on the other side and nipped up with a tiny socket. It then left a stainless stud that I could attach the mud flap bracket. The nut and washer left enough clearance to stop the bracket deforming on the shape of the out rigger. Also the air gap means I can flush any mud out when I wash it. Saves holding moisture between the metal surfaces. The length of tud was protected by the bracket so not hanging down. Also I didn't have the right rivnuts but loads of stainless nuts and bolts. Also painted the outrigger while at it and fitted then galvanised mudflaps. Looked far better than some rusted out hanging down flaps.... |
31st Jul 2017 7:55pm |
mattmadman1990 Member Since: 15 Feb 2017 Location: derbyshire Posts: 21 |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Expensive way of doing it but I just bought new flaps and brackets from tuffrok and used new riv nuts and bonus being stainless brackets |
6th Aug 2017 10:04pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 |
I keep looking at the state of my mudflaps and associated 22 year old bracketry and am seriously contemplating the Gynn Lewis mud flap kits with the extra bits that protect the chassis and outriggers/rear crossmember better. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
7th Aug 2017 6:41am |
