Home > In Car Electronics > Using the crossover filters or original wiring?
dantastic
I assume that when installing component speakers into a Puma I use the crossovers that come with the speakers and as input to the crossovers I only use the bottom set of speaker cables. The Puma has leads for the tweeters but I assume that there is no crossover filter in the standard wiring. This is all right yea?
Post #641891 4th Aug 2017 3:45pm
OE Tweeters have the X over in-built in the Tweeter.
With that removed there isn't one fitted unless you fit one in-line aftermarket. KEEP CALM AND Drill ON
Post #641899 4th Aug 2017 4:19pm
dantastic
Ok, perfect. thanks.
Post #642395 7th Aug 2017 2:52pm
Thumbs Up KEEP CALM AND Drill ON
Post #642442 7th Aug 2017 6:09pm
