Home > Td5 > TD5 FPR gasket question
srod
About 18 months ago I replaced my badly leaking FPR with one of those £40 kits off ebay, which was generally successful.
However now (after fixing another leak from the rocker cover gasket), I'm noticing a slight leak again - so I'm going to take a punt on just replacing the gasket, and if that doesn't work I'll bite the bullet and just get the full genuine FPR.
My question is, can anyone tell me what the 3 O-rings and sealing washer is for in the following gasket kit that I have just bought. I don't remember them from last time, and can't find a mention of either of them in the online guides that i followed last time.
http://www.ebay.co.uk/itm/262049972354
3 X O RINGS - STC4509
1 X WASHER SEALING - ERR6192
Cheers!
Shane.
Post #641638 3rd Aug 2017 3:56pm
NickEJ
Slovenia 2004 Defender 90 Td5 XS CSW Galway Green
Have a look on You Tube, there are a load of videos. Just be aware that there are two types as I think the design changed for the 15P engine.
Post #641676 3rd Aug 2017 5:43pm
4wd-junky
You'll have 3 o'rings for the screw in pipe fittings. (2 for 10p or 3 for 15P). The 'fat' o'ring sits into the head.
The sealing ring is probably for the temp sensor.
Also, I've had good success rebuilding TD5 regulators using VW o'rings and used Bosch 4 bar regulators from a local breaker fitted with a new genuine LR gasket. Works out a very cheap repair with quality parts. Thumbs Up
037 198 031 O-rings
BOSCH 0280160516 (remove round filter)
Gaskets are:
MSX100080 10p
MSX000010 15p
Post #641687 3rd Aug 2017 6:28pm
