Home > Maintenance & Modifications > 2.4 tdci remap
arran jones
2.4 tdci remap
Hello all forum users...
I have a 2 4 defender 90 pick up and im desparate to get a ecu remap on it
Ive had a look at avon tuning in bristol and they can actually come up to me and do it where im based
They will take it up to 158bhp and 420nm and delete the EGR for £250
Does anyone on here reccomend this company and would a remap that size make a big difference??
Thanks alot Thumbs Up
Arran
Post #636022 6th Jul 2017 8:44pm
Alive Stage 1 can be done at home if it's a 2.4. 150hp or there about and 420 torque.
Had mine a long time, faultless.
Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #636030 6th Jul 2017 8:55pm
Caterham
Hi mate,
There's numerous suppliers out there and they'll all tell you their's is best likewise I will with mine Very Happy
Might be tricky but see if you can get hold of Ian at IRB and try / do a road test of one already tuned.
I'm up at circa 450 Nm having had a 410 Nm tune en route. With egr delete you should see an immediate 10% drop in fuel consumption.
Low end pull is amazing and it just keeps going Thumbs Up
Most recent mod for me was removing the centre box. Doesn't make much difference but it all adds up to a much nicer drive Thumbs Up
Post #636033 6th Jul 2017 8:58pm
arran jones
Ok cool...
Thanks for the quick responses
Will see when i can book my machine in for.....and will let u know the outcome
"Puma2010" is on here somewhere (good friend of mine!) Hes had it done and is very impressed! Very Happy
Post #636043 6th Jul 2017 9:22pm
zsd-puma
I've got a BAS one giving similar power and upload it via my IID tool, so i can upload it and replace with the standard one when ever i want.
Yes it makes a massive difference, but don't be lazy with the gear changes as it will make your clutch grumble.
Post #636090 6th Jul 2017 10:50pm
Naks
BAS or Alive ! --
Post #636182 7th Jul 2017 10:44am
mrjsray
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Santorini Black
A bit late I know, but I had my 2.4 110 remapped today using Superchip's Bluefin set up and the difference is incredible. Too early to say about fuel economy.
I have used Superchips on 6 different cars and all have been really good remaps. It's worth noting that they have a sale on too so the bluefin remap is sub £300 which is v good.
And, no, I dont work for Superchips nor do I have any affiliation with them. And no, I wont say that they are better or worse than any other remappers on here. They have just proven to be good for me.
Post #641419 2nd Aug 2017 4:21pm
Increased fuel economy does in my view pay for the remap its self over a longer duration. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #641426 2nd Aug 2017 4:50pm
corgi1
England 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
DYNACHIP all the way, he comes to you very knowledgeable, and allways on the end of the phone - faultless, and now drives beautifully, with plenty of power.
Pete
Post #641441 2nd Aug 2017 6:31pm
Stacey007
Who does these remap near Chester?
I think after 2 years of normal power I might dip my toe in.....
Post #641442 2nd Aug 2017 6:52pm
ericvv
On a 2.4 Tdci, can any of the tuners on here provide the following?
EGR electronic permanent shutdown, but no further engine power/torque tune whatsoever. My supposedly 122HP and 360Nm suit me fine.
Guaranteed no MIL light ever showing up due to the above.
Ideally from a distance without having to bring the truck to the U.K.
If possible, next question is if my dealer will notice this when plugging the truck into their system? And could they mess up this ECU change then, even inadvertently?
Thanks, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #641443 2nd Aug 2017 6:58pm
^^^^ Alive can do that. You can do it at home if it's a 2.4.
You're just looking for EGR shut down on its own, then I think that's quite cheap too. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #641444 2nd Aug 2017 7:09pm
zsd-puma
BAS also offer that service too.
Post #641563 3rd Aug 2017 12:18pm
Grenadier
Thanks, Eric
I think I am right in saying that you can see a remap on the ECU if you go looking for it and know what you're looking for. So the dealer (may) come across it, or may not depending on what they are diagnosing in your ECU, where and why. A test centre can't, (unless in Switzerland it includes a ECU test), the closest non-ECU test being fixed gear, rolling road speed tests. Even that isn't too reliable apparently. Obviously if you get an older style 'plug and play' module, you can take it out before visiting the dealer/test centre and replace after, if you're worried, but I assume it will be more expensive than a straight data upload as it will include a module and cables. However, I think BAS do do one for a 2.4... Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #641576 3rd Aug 2017 12:59pm
This is sounding like a competition. Laughing
Yes, I think there is a workshop upload or a map and device etc like I have the ATRIC. from Alive. (Think there may be a newer unit now?).
With the electronic tool you can read and clear DTC's and load the original map and swap if you like.
I'd imagine BAS probably have similar.
This applies to a 2.4 but a 2.2 I believe they either need it in or the ECU. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #641578 3rd Aug 2017 1:21pm
