![]() | Home > Technical > Are these the most boring set of Defender images ever taken |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5116 ![]() ![]() ![]() |
Are these the most boring set of images ever taken (copied from an Argentinian Land Rover Web Site)
Obviously there is not a lot for Land Rover owners to do in Argentina, except look at gauges and dream of re taking the Falkland Islands......... ![]() However it has got me wondering if anyone has got pictures of the following I would be interested in seeing a series of pictures showing a dipstick with varying oil levels. ![]() Or perhaps a series of pics showing the gradual colour change of the coolant as antifreeze is added in millilitres ![]() I would also like to see a series of images showing a land rover clock at every minute position ![]() I am also considering starting a thread with pictures of a tyre at various pressures. ![]() A sequence of photos showing a jam jar slowly filling with brake/clutch fluid during brake bleeding would also be worth seeing I feel ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() http://www.youtube.com/user/conwy1 |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2205 ![]() ![]() ![]() |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1049 ![]() ![]() ![]() |
It's a while since I drove a Td5, but I never did trust the fuel gauge. 300 miles = time to look for a filling station, 350 miles = call rescue service.
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Don't know, I couldn't be bothered to look after the first 2 images 😂😂😂
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Errr yes
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
To be fair, my td5 is like this. Full full full full full full halfway empty oh dear! |
NickEJ Member Since: 24 Nov 2012 Location: Ljubljana Posts: 152 ![]() ![]() ![]() |
It's nice to see the fuel guage going the other way for a change.
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 ![]() ![]() |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7910 ![]() ![]() ![]() |
Not going to ask how you found them Gilarion!
![]() ![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
that reminds me; I need to fill up in the morning
Iain_S Member Since: 03 Sep 2014 Location: West Lothian Posts: 8 ![]() ![]() ![]() |
The Defender one on the left? is a lot more accurate than mine. I reckon 3/4 is actually about 1/2, and after 1/4 you can almost see it going down.
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
No. I would actually like to see a similar set for a 2.2 Puma, just to see if anyone else's is as non-linear as mine (apparently they are all like that sir
I wondered what response these pictures would generate.
![]() And no one has grasped the significance: lol: To be fair, that series of photos uploaded from Argentina gives a well-composed and important insight into the accuracy of a fuel gauge, ![]() It also goes to show how a gauge if Land Rover would have incorporated a more dynamic needle with a wider arc of movement to give more precise and therefore more reassuring visual readings of the remaining contents of a tank of fuel, and so allowing for the true magnetic north in your part of the northern/southern hemisphere and the effect of the slight magnetic fluctuations this would cause a slight ellipsoid and not a slight deviation of the needle in accuracy. ![]() So using this formula E = {x 2 En | kAxk = 1}, and the geometric significance of all Lode lane Land Rover engines and allowing for orthogonal changes, I can now say that the accuracy would have a Mean Curvature and an integral curvature of twelve cms per lunar night. I think if you carefully study the time lapsed photos you will see that I am spot on with this measurement. ![]() For anyone who does not understand the above I can only say you need to continue to be a member of this forum for at least another month read all the posts and then realise to own a Defender you have to be either totally mad or at the very least sane and willing to wave at every other barmy owner you come across on the road. ![]() ![]() ![]() For those who do not have a working fuel gauge I can only say Comic Relief has a fund please apply. ![]() And for those who know what I mean including those from the Argentines then well I do not have to explain. ![]() Personally it does not matter to me as I cannot afford to fill my tank each week with more than I fiver anyway. ![]() ![]() http://www.youtube.com/user/conwy1 |
Forget 54 Litros ... I'll have a pint of what you're on
