Home > Maintenance & Modifications > From simple Puma 110 HardTop to PopTop Overland Camper
Page 4 of 5 <12345>
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
Very interesting, look forward to seeing more Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #550636 23rd Jul 2016 1:34pm
Simon.pl
Poland 2007 Defender 110 Puma 2.4 HT Keswick Green
Thanks Charcoal - will post some more pictures soon Thumbs Up
Does anyone know if the extended wheel arches (like Terrafirma ones) are same as the original ones looking form inside? So do they cover the inside nicely or they just clip on on the outside of the fender and there is a gap over the wheel where the mud can get into?
Post #550646 23rd Jul 2016 4:00pm
Simon.pl
Having a Defender with pop top conversion there is a little challenge when still wanting roll cage to be installed.
I've decided to build external/internal combination based on Raptor4x4 cage I bought second hand (from Defender 90).
Two main arches are installed inside - one behind the front seats and the other one at the back of the car. Both made of 50mm tubes.
Front and rear mounts were plug and play - the middle one had to be modified. Made of SS - one leg you can see is screwed in the frame from the side - the other one (not visible on the picture) sits on top of it.
Similar to the rear one.
Stainless bolts are used to fix it - will paint them black when the paint job will be carried.
Two strengthening bars were added - make the whole design stronger in case of roll, but still allows to get to the back of the car from the front seats.
As you can see - the lower frame is almost ready Very Happy
It's not perfect - as there is a gap above the windshild, but it's as big as it was while the original roof was installed - around 1cm. Still got the feeling the rear panels could be lowered around 0,5 cm, but will take care of it later.
Door seal fits fine - you can see new, a little bigger profile used for the seal on the other side (driver's side)
External part of the roll cage being installed.
Decided to keep the side tubes 11cm far from the frame as I want to install my James Baroud awning I'm having in my Discovery, on top of it, and it's 10cm deep.
I know it's not perfect solution as in case of any serious accident the upper part of the car will be damaged, but at least we should be safe inside and this seems to be a good compromise between safety and functionality.
Thumbs Up
Post #551965 28th Jul 2016 6:49pm
charcoal
Very good, your pop top is coming along nicely Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #552020 28th Jul 2016 10:01pm
Simon.pl
Cheers, Charcoal
Enjoying the project Thumbs Up
Post #552046 28th Jul 2016 11:35pm
Simon.pl
Been few weeks since my last post here.
It's due to starting the build thread on the FB page as I'm more often there than here. If anyone interested - https://www.facebook.com/OffRoadProwlers/ here it is.
By the time the roof can be opened
strength of the frame checked twisting the chassis
gull wing windows are almost ready (just need to instal the gus struts),
the raised air intake is ready from outside,
and the water tanks are being finished.
All good so far.
If anyone would like some details here, let me know. As there was little interest in comments decided not to go for detailed description of the build, but feel free to ask if curious Thumbs Up .
Post #564834 18th Sep 2016 1:55pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Awesome build so far Simon Thumbs Up
Just two points reading through about the roll cage, you said you have utilised stainless steel bolts, I assume you have fitted the correct strength rated ones and not just normal ones, also very unlikely I know but one of the wagon platforms I have at work had rails running just above the doors, it was only after a couple had rolled we realised that this bar was bent downwards and prevented the door from opening, just somthing you might like to check. Hopefully the worst will never happen but I would rather pass this info on than not.
Keep up the good work Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #564839 18th Sep 2016 2:17pm
Simon.pl
Just realized it's been almost a year since my last post here Shocked
Well - started to tear the car down around January. A friend of mine let me place it in it's little workshop and the big journey started. It took me about 4 months to have the chassis and and body ready, but I do 95% of the job by myself so it's rather slow (it took around 100 hours to have the chassis ready for bathing and another 60 to have the body ready for spraying).
The chassis was zinc bathed
and then sprayed with Line-x
Also all the panels were sprayed with Line-x as well
Started to build the car from the ground up around mid May.
Ashcroft ATB at the front and Full Locker on the back were installed as well as MT82 shaft improvement (what a pain removing the old one!!) Underbody parts were refreshed and was really happy when I finally saw it standing on it's wheels Very Happy
Now slowly putting all the parts together and trying to find "what should go where" Laughing
Still long way to go but I think it's the best way to know your Defender Thumbs Up
Post #640774 30th Jul 2017 7:47pm
Simon.pl
Post #640775 30th Jul 2017 7:48pm
L110CDL
Thank you for posting this back on def2 as i dont do facebook Rolling Eyes what a journey that you have been through and now you can see the light at the end of the tunnel, great build Simon Bow down 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #640784 30th Jul 2017 8:29pm
Simon.pl
Thank you Clayton Bow down
I was just looking for some informations here again and though I "owe" something to all those great people sharing their knowledge here so decided to post back here about the progress. Maybe somebody will find it useful.
Got TONS of pictures and after all that "little things" that had already been done to the Defender it's really hard to pick up the right stuff just for one post so when I find more time will write more detailed description of what had been done and how. Let just leave the previous post as a starter Mr. Green
Post #640786 30th Jul 2017 8:36pm
L110CDL
Thank you for the " starter " pic's Thumbs Up will look forward when one day you have enough time to " update " this thread, thank you again Simon Wink 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #640791 30th Jul 2017 8:56pm
Simon.pl
Resurrection post again Mr. Green
As the car been driving since few months decided to make a short update of the progress. Few "mile stones" in next few posts Thumbs Up
Ashcroft upgrade for the MT82: It was a REAL PAIN to install. Well. To remove the old one.
Dynamating was nice and easy though Wink
Than there was a time for aircon install. Bought the kit from Devon4x4. Not very intuitive manual arrived with it, but managed to do it.
Engine will work a little cooler with new intake, new intercooler, hoses and exhaust from Alive Cool
Post #734700 14th Oct 2018 3:55pm
Simon.pl
Inspired by the post I've seen once I was digging for some ideas where to go with the mods on my Puma, decided to give it a try and install the trip/board computer on the instrument panel to have clear view for the most important parameters of the engine, or simply use it as a trip computer.
Bought the UltraGauge from the USA that is able to read about 48 parameters of our Defenders systems, read and clear the trouble codes and decided to embed it in the dash.
Striping the instrument panel seems more tricky that is in reality - just need to be careful when removing the pointers and generally dealing with the whole thing (the plastic is very soft I would say), but in the same time it's quite easy to work with as it does not break easily. Whole operation took about 5 hours including OBD wires desoldering/soldering that wasn't necessary at the end.
Post #734705 14th Oct 2018 4:24pm
Simon.pl
Additional fuel filter install.
10 micron pre-filter with the water detection system. Have it between the tank and main fuel filter. A little unfortunate place considering safety of the filter, but quite good when thinking of making new fuel lines. Some kind of cover should protect it from stones and mud and there is easy access to inspect and drain if needed. Using copper brake cord to get the shape the lines should have.
Been looking for quick connectors being used in original fuel lines and also the material I could make the new lines from.
From my research it seems like poliamid (Tekalan) pipes (PA12) could be a good choice as the rubber ones are not as durable as I would like them to be.
Additional fuel tank design and install:
It has around 52L (that is the amount of liters I was able to fill it with, so tested, not calculated) Wink
Down side - rear shaft touches it sometimes on bigger bumps and I didn't do serious off roading yet Big Cry Will need to be removed and modified a little..
Post #734709 14th Oct 2018 4:55pm
Page 4 of 5 <12345>
