Home > In Car Electronics > Can anyone help with switch wiring (heated seats)
Welkman
Hi guys,
I have fitted an exmoor trim heated seat unit which consists of a relay with four wires coming from it going to a three way switch (circuit on for low, circuit on for high, off). The switch at the moment lights up green all the time and gives 12v to the heater elements only when switched to low, it should only light green on low, be off when the seats are off and red when switched to high power. Under high power no power goes to the seats.
I did cut and extend the loom as it was too short but have checked continuity of my extensions and am 100% that they are correct.
I have not tried moving the connections on the switch yet as I am fairly certain that it would not have come from the factory incorrectly connected?
Any ideas on what to check?
Cheers James
Post #640409 28th Jul 2017 7:54pm
pepethekingprawn
United Kingdom 1989 Defender 90 V8 Petrol ST Auto Chawton White
Where are you getting 12v supply from? Did the kit come with a wiring diagram?
Post #640911 31st Jul 2017 1:44pm
