![]() | Home > Maintenance & Modifications > 110 Rear discs and pads |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2690 ![]() ![]() |
110s use a larger rear disc than the 90 models, it's the same non-vented disc as used on the front of 90s. The 110 rear calipers (2-piston units) are different dimensionally to suit the larger disc.
I think you're wasting your time though. You will gain nothing by putting 110 rear brakes on a 90, plus they're smaller for a reason and I don't think upsetting the brake balance as designed by Land Rover is very wise. Rear brakes do very little under most conditions anyhow. |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5226 ![]() ![]() |
Thanks for the info Retroanaconda, I will just upgrade the fronts to vented with replacement calipers, as I do have a brake imbalance, and put new discs and pads on the back then. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
