Home > Maintenance & Modifications > Clear Indicator lenses
Page 1 of 4 1234>
Hello,
Just a quick question are the clear indicator lenses combined with amber bulbs road legal for the front of a Puma 90? Also where would you suggest buying them Bolt on bits on Ebay?
Cheers, Steve Thumbs Up
Post #63961 16th Mar 2011 5:17pm
Grockle
Yes and the back 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #63963 16th Mar 2011 5:19pm
And the clear brake light lenses with red bulbs?
Post #63966 16th Mar 2011 5:35pm
mse
Got them on the back of mine!
As long as the bulbs are "E" marked your fine. Mike
Post #63970 16th Mar 2011 6:00pm
don't suppose you have any pics available do you?
Post #63971 16th Mar 2011 6:09pm
What i was maybe thinking of doing is changing the rear fog lense to wipac clear with a red bulb. Wipac clear rear brake and indicators with appropriate coloured bulbs and obviously the same on the front also. and rdx clear side repeaters (as Wipac don't seem to do these)
Post #63976 16th Mar 2011 6:36pm
mse
try this Mike
Post #63977 16th Mar 2011 6:37pm
BigMike
can I ask what the point of these is? I dont mean to be controversial but I've always wondered.
Post #63978 16th Mar 2011 6:39pm
As such I would imagine there is no point at all other than looks purely and simply looks
Post #63979 16th Mar 2011 6:40pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I just finished doing this a couple of weeks ago, including the clear Wipac reversing light to replace the fog lamp with a monster bright led cluster in it. I put leds into everything including the numberplate lamps, but not the clear indicators, as I didn't want to mess around with having to change the relay and risk losing the trailer indicator on the dash. I really like the look with all clear lenses against the grey paintwork. It looks much cleaner looking compared to standard with the different coloured lenses.
The only one I haven't any idea how to do is the high level brake light lense. I've not seen these available anywhere with clear lenses.
Pete
Post #64023 16th Mar 2011 10:49pm
dgardel
Italy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #64024 16th Mar 2011 10:58pm
XS Pete
And one from me:
[/img]
Post #64048 17th Mar 2011 8:50am
XS Pete wrote:
And one from me:
[/img]
This is what I was after doing myself. Would i be right in thinking for the fog you used a reversing light lense with a red bulb of the same type (LED in your case)
Post #64063 17th Mar 2011 10:58am
I think it is to make it harder for the bloke behind to anticipate which lights are important and therefore increase the risk of him running into the back of you. Very Happy
I like the location of my brakelights to be as obvious as possible - nowadays it is more likely than not that the guy behind is a moron who needs all the help he can get!
Post #64075 17th Mar 2011 12:33pm
XS Pete
Spot on. I bought a standard Wipac reversing lamp identical to the normal one on the left-hand side for about £6 from John Craddock or Rimmer Brothers or similar. With an LED cluster like this one inside:
http://cgi.ebay.co.uk/1x-RED-13-LED-BA15S-...519805d0a2
brightness is definitely not a problem. It's eye-burningly bright. Thumbs Up
Pete
Post #64079 17th Mar 2011 1:43pm
Page 1 of 4 1234>
