Home > Maintenance & Modifications > Best way to wire light bar
bear100
Hi chaps
Looking to wire some accessories shortly and after some advice on how to tackle it, firstly starting with the roof rack laser light bar.
I have a blue sea fuse box and carling switches, and will want to tie in with full beam Very Happy and still be able to turn on and off via the carling, how would be best to?
Thumbs Up Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #639853 26th Jul 2017 12:04pm
grafty99
Best thing to do is wire the main beam trigger wire through the carling switch. If the switch is on then the light bar will illuminate with the main beam and if it's off then it won't Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #639854 26th Jul 2017 12:10pm
grafty99
Then use power via the blue sea fuse box to a relay controlled by said switched trigger Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #639855 26th Jul 2017 12:11pm
bear100
Ah sounds like a good idea Exclamation where would be best to pick up the trigger wire? Near the light? Thumbs Up 2023 Defender L663 V8
Post #639937 26th Jul 2017 6:32pm
grafty99
Probably the high beam tell tale wire behind the dash Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #640410 28th Jul 2017 8:13pm
