Home > Maintenance & Modifications > Cost of upgrade for higher final gearing on my 90
Telshe
England 2004 Defender 90 Td5 XS CSW Cairns Blue
Can someone give me a ballpark figure for the disco 2 final drive gearing. I believe it is a 1.14 transfer box.
Supplied and fitted plus I believe you may need to renew the clutch while very thing is out. My defender is a 90 XS of 04 vintage
Many thanks for any replies
Entel
Post #639384 24th Jul 2017 2:00pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Cheaper to buy a disco 2 transfer box or speak to Shabs piercy at synchro gearboxes 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #639394 24th Jul 2017 3:04pm
bankz5152
Yep. Shabs or Ashcroft buy a Disco box from them or buy a used box and have a garage fit it. Depends how much you want to spend really.
Post #639401 24th Jul 2017 3:47pm
ibexman
Around £900 supplied fitted by Ashcroft
Post #639403 24th Jul 2017 3:51pm
Lotus_esprit_s1
Or £75 for a used disco transfer box (they very rarely fail) and couple of hundred for fitting, or do it yourself with som help to lift into place.
Post #639775 25th Jul 2017 11:12pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
As Lotus Esprit says, I'm on my 2nd Disco 1 transfer box in the last 10 years.
Bear in mind you'll need to change over the Diff Lock mechanism. Also the D2 transfer box is different as the D2 does not have the diff lock activation kit as standard although the early ones do have the external drive for the linkage which the facelift doesn't. The D2 diff ratio is fractionally higher geared and has 'Quiet Gears' fitted, as does the Tdci Defender transfer box!
Post #639920 26th Jul 2017 4:57pm
