![]() | Home > Maintenance & Modifications > Where to buy precut Dynamat ? |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
Hi all , as the title suggests I'm after some dynamat.
I've heard it's worth buying it pre-cut as it saves hours on labour. I've found a couple of kits for 90/110 but nothing for a 110 double cab. I don't want o pay for bits I won't use ! Any ideas ? Could've sworn I saw one on eBay a few weeks ago. ![]() Click image to enlarge |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1769 ![]() ![]() ![]() |
To be honest, a few sharp Stanley blades and a piece of plywood to work on is all you need. You won't waste any as all but the smallest scraps can be used.
The increased cost of a pre cut pack will far outweigh the half sheet you might waste in a bulk pack! |
Ok thanks guys , I'd read it takes a lot longer to cut it to size yourself that was all.
I may have to resort to a bulk pack |
Depends, as much as some people will go for it, you really don't need 100% coverage, anything over about 50% is meant to have practically the same effect
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20626 ![]() ![]() |
^^^^ Very true, but I like 100% as for the cost you may as well get 100% effect and it's fit and forget.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
