Home > For Sale & Wanted > [For Sale] Mobile storage draws
windymiller
2x mobile storage system
This is the stack & stow Draw £168
And the stack &stow flipper £162
So each would cost £348 plus postage
The pair together £480 or £240 each
Both have the odd extra whole where the had fixings in the top for tie downs etc , the both were carpeted on to so things didn't slide or rattle . If you re did them after fitting you do not see the holes .
Post #637763 16th Jul 2017 8:15am
windymiller
Open to sensible offers Bump
Post #638735 21st Jul 2017 6:21am
big ives
what's the actual sizes?
I am looking for ONE set of these to fit in my 90 CSW, I have inward facing rear seats, HOWEVER I have one seat removed and I THINK one set these boxes would fit in the space vacated by the seat, that's my plan if the measurements are correct?........................................cheers Ivan
Post #638759 21st Jul 2017 9:26am
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Hi Ivan
They are 440mm wide. I have them in the back of my 110 - excellent bits of kit. Recently had a wanted ad on here for a single flipper (but MSS finally came through).
Tony
Post #638784 21st Jul 2017 12:29pm
windymiller
Give me a shout Ivan ,they really are great storage ..
Mark
Post #638891 21st Jul 2017 10:02pm
big ives
Mark
please send me a private message with your email and I will contact you...............................cheers Ivan
Post #638988 22nd Jul 2017 12:34pm
big ives
Mark
As I said I have a 90 CSW with one of the rear inward seats removed, in the space I would like to fit a storage box at least one on top of each like you have advertised , however as you know the space is limited.
When fitted in you landy had you them fitted in the same place on top of the wheel arch box so that one sat on the wheel arch box, the other sat on top just up past the window (well in my case a window) but you should get my drift.
The other issue I am aboard offshore getting back to the UK 4th August when I can take measurements to see if they are good for me. So if you could give me length depth and height that would be great, I will be honest with you if the measurements fit my space I WILL BY ONE SET FROM YOU Bow down Bow down Bow down
Also my internet here on the rig in Malaysia is having issues for over a week, as sometimes I can’t send or open PMs on my landy forums. I see you sent a PM but at the minute I can get it to open but will keep trying to open it. Big Cry Big Cry Big Cry Big Cry Big Cry
Very best regards Ivan
Post #639122 23rd Jul 2017 10:08am
windymiller
No Problem they are 440 wide and designed specifically for the defender wheel arches the bottom box is deeper to fit into the recess of the bodywork
,you can fit 2 boxes deep on a 90 they are brilliant and very useful
Give me a shout when you get your messages
Post #639348 24th Jul 2017 7:43am
