Home > In Car Electronics > Solar Panel
zsd-puma
Solar Panel
Currently i've got an AA solar trickle charger connected when i'm not using the car it works a treat.
However i'm thinking of connecting it up permanently.
What i'm not sure of though is if it will get damaged by the car's alternator output if it's connected while the engine is running or if the starter would try to draw current from the panel and damage the panel when i start the car.
Post #638676 20th Jul 2017 7:26pm
VeeTee
Netherlands
I have a 60 W solar panel permanently fitted to to roofrack, it is connected to the dual battery via a solar regulator and a Cyrix VSR. I have this set up now for about four years, and no problems whatsoever - and I use my Defender as a daily driver, so lot of starts have passed since... Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #638682 20th Jul 2017 7:47pm
If I were going to leave a simple panel permanently connected, I do it via a changeover relay so that it was only electrically connected when the relay isn't energised. Darren
Post #638697 20th Jul 2017 8:45pm
zsd-puma
That makes sense. Do you think it would damage the panel without a voltage sensing relay?
Post #638707 20th Jul 2017 9:33pm
I think you'd be hard pressed to find a panel these days that doesn't have some sort of regulator built into it, which should provide ample protection. Darren
Post #638714 20th Jul 2017 9:47pm
zsd-puma
I think the panel was only £20 anyway. So it wouldn't be a great loss if it died after a few months.
Post #638726 21st Jul 2017 1:39am
