Home > Maintenance & Modifications > Side steps - whats the difference?
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I want to get some new black side steps mine are currently chrome
There are two types available, the one which I prefer with twin fixings on the top of both upright supports
http://tmdtuning.com/shop/tmd-black-side-runners-90110/
Or the set with four fixings. Two fittings on the upright supports plus two cross bars which bolt on to the bottom of both the upright supports with fixings at each end (below) By the way I know the bottom set are for a 110 but they are exactly the same for the 90
https://www.sidesteps.co.uk/shop/side-step...ide-steps/ 2010 Defender 90 HT
The longer I live..... The better I was!
Post #638627 20th Jul 2017 2:21pm
Rodney-too
England 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
the TMD ones are same (design) as the OEM ones that came on my 90XS - probably the same manufacturer. They are easy to fit, but I would give the insides and brackets a good dose of rust treatment, as they rust from the inside. My 6 year old original ones had holes the size of 10pences in several places, so have replaced with these.
Look great IMHO.
Post #638635 20th Jul 2017 3:06pm
Butchers Boy
^^ Thumbs Up 2010 Defender 90 HT
Post #638679 20th Jul 2017 7:39pm
leeds
Or these http://www.4x4overlander.com/product/rapto...-steps-90/
90's in stock but. 110's also available
Nakatanenga quality as always
Regards
Barbara
Post #638703 20th Jul 2017 9:14pm
Butchers Boy
Thanks Leeds... Thumbs Up I have already ordered the one's from TMD..... Very Happy 2010 Defender 90 HT
Post #638710 20th Jul 2017 9:40pm
B4Lamb
Wales 2007 Defender 90 Puma 2.4 HT Galway Green
How long do these last before rust starts to show? On the tubes or brackets? "You are never to old to learn something new"
Post #644790 17th Aug 2017 10:16pm
B4Lamb
Bought some unpainted XS style side bars from MPS trading, unpainted not being normally available. I then prepped these and had them hot dip galvanised. I then painted with black Vinylast paint and fitted the checker plate with stainless screws. Perfect job that will not rust out in a few years as the zink coating is both inside and outside on all surfaces, including all the brackets supplied. "You are never to old to learn something new"
Post #649499 10th Sep 2017 11:02pm
zsd-puma
The TMD ones will also have the tubes going back to the chassis, they're just not shown in the pic. The Genuine ones have the tubes back to the chassis, they wouldn't be very strong with out them.
Post #649500 10th Sep 2017 11:22pm
B4Lamb
Are the TMD ones just painted mild steel? They are quite pricey. Some of the retailers describe an optional zinc coating prior to powder coating but it's only applied the outside of the main tubes not internally. The 4x4Overlander ones are painted stainless from what I read so they should last. Not sure what grade of stainless though A2 or A4? "You are never to old to learn something new"
Post #649521 11th Sep 2017 7:56am
