Home > Maintenance & Modifications > Accessory sockets
neil
United Kingdom 2012 Defender 90 Puma 2.4 CSW Alaska White
Accessory sockets
Decided to fit an extra one in the front & back.
Sourced a pair of surface mount ones from Ebay (£9.00). To fit rear I removed the rear driver's side speaker and used the spare power socket connector. Made an extension lead up and ran through a drilled hole behind where the socket is screwed to.
Fitted the front by sourcing the power from the back of the existing cigar socket, job done.
Can't work how to upload photos into here Shocked so take a look at my gallery!
Post #6371 17th Jan 2009 7:27pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Nice place to put the front one. Hmm, i wonder if the rear speaker panel would fit behind my second row of seats? It's just bear there and only have the front speakers. 130 crew cab
98 V8 Disco
Post #6372 17th Jan 2009 7:36pm
mse
I put a flush one there as there is enough depth to do it
 Mike
Post #6373 17th Jan 2009 9:05pm
Grockle
Neil,were did you actually locate the extra front socket ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #6383 18th Jan 2009 11:29am
neil
Grockle, It's on the bottom right of the grab handle - there's a pic in my gallery.
Post #6400 18th Jan 2009 9:16pm
Femund
Norway 2008 Defender 110 Puma 2.4 XS CSW Java Black
 08MY Defender 2.4 SE
Post #6404 19th Jan 2009 7:13am
Grockle
Thanks ,very neat job. 2.4 90 XS
Post #6405 19th Jan 2009 8:27am
dgardel
Italy
Femund wrote:
Where do you bought the socket support?
Ciao
Daniele
Post #6455 21st Jan 2009 9:45am
neil
Post #6480 21st Jan 2009 7:22pm
TJ101
neil wrote:
Here is where I got mine from
http://cgi.ebay.co.uk/SURFACE-MOUNTED-POWE...m153.l1262
Cheaper now, if you have a pair http://cgi.ebay.co.uk/SURFACE-MOUNTED-POWE...240%3A1318 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #6483 21st Jan 2009 10:20pm
