Home > Maintenance & Modifications > Fitting boomslang loom - earth problem |
I extended the RH earth across to the LH one, then ran a cable right back to the main battery earth on the chassis. I don't see the point in running the positive to the battery if the earths are then rubbish.
Get some harness tape or flexi conduit and you can run the earth lead along side the battery positive. |
18th Jul 2017 4:28am |
Probably different than the Boomslang, but with the Landreiziger loom you only need to connect the plus to the permanent live at the alternator and then take a single good earth connection. In below picture it shows my easy earth taken at the top of the engine compartment where there is a bolt in place already and in a location which won't see moisture. No point at all to connect all the way to the battery.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
18th Jul 2017 5:09am |
pme Member Since: 06 Jan 2016 Location: cambridge and mainly ariege Posts: 49 |
Keep an eye on the fuseholder, mine melted. Hopefully they may have used a better quality one now.
18th Jul 2017 2:33pm |
Gordo Member Since: 08 Jul 2015 Location: Surrey Posts: 29 |
Thanks for the input - great pic Eric, I've earthed both lights to that point. Sorted.
Now to decide if I like the clear led lights ive just fitted on the back vs to the coloured originals they replaced.....decisions decisions Gordo |
18th Jul 2017 7:28pm |
