Home > Puma (Tdci) > How many ... |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
...HP does the Defender has? is it 122 or 140 ?
I've been having a discussion on Portuguese forum about the Puma engine ... I have a friend that says that the 2010 model has allready 140 bhp from factory ... Is it true ? I was told that it had 122 like the Td5 used to ... Any thoughts ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
13th Mar 2011 10:08pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
The latest version of the workshop manual also states that it is 140PS. So, maybe they changed it recently.
Pete |
15th Mar 2011 12:46pm |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 |
Yep, 140ps or 138bhp. It was discussed to a conclusion in a thread on here fairly recently. D300 HSE 110
15th Mar 2011 12:56pm |
Still, always and forever 122hp (90kW)!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
15th Mar 2011 1:43pm |
can you find a print, or print it, and post it here ?
did not find it ... can you point me to the thread ? I need to find arguments to maintain, or not, my discussion on the portuguese forum
My thoughts exactly ... I've searched a lot and could not find anything written that says otherwise ... ... not forever if you get a remap ! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
15th Mar 2011 2:27pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Not enough 130's have feeling's as well you know
15th Mar 2011 2:54pm |
If you have a look in the .PDF manual which Daniele sent out links to recently it's all over it.
For example: page 6 in the index: 303-01: Engine - 2.4L Duratorq-TDCi HPCR (103kW/140PS) - Puma page 292: Engine - 2.4L Duratorq-TDCi HPCR (103kW/140PS) - Puma - Engine Description and Operation I spotted 21 references to it in the index alone. Pete |
15th Mar 2011 4:05pm |
good idea ... did take a look, and you're right, but on page 295 it's also written this it's not important, but I'm just curious... Is it diferent the engine power and power output ? Are both informations correct ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
15th Mar 2011 5:19pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
From TOPIX website for my 2010 Defender 90:
Engine:2.4L DOHC HPCR DSL 140PS PUMA Are we getting confused between the Engine output measured at the flywheel, and the Vehicle output measured at the wheels or similar. NB: I'm not an engineer and haven't the foggiest if this is correct or not. |
15th Mar 2011 5:38pm |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 |
IMHO, the engine itself, being used by Ford as a 140PS power plant is capable and known as a 2.4L - 140 PS unit, however Land-Rover has modified the ECU maps such that it only produces (a typical) 122 PS in our Puma Defenders. Peter,
Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
15th Mar 2011 6:09pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
I assume BAS or Alive who know these engines ECU maps would know the answer! BM52
15th Mar 2011 7:22pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
All my last 4 drove the same, ( 07MY to 11MY ) bar the SVX, which i did not buy new, and recon it had been played with
But does it really matter ??? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
16th Mar 2011 8:35am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 |
+ the use of lower tech injectors Puma 110" SW ............................................................. Earth first. Other planets later |
16th Mar 2011 11:03am |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 |
Typical of LR to state two different outputs!
122bhp AFAIK - not 122PS. Defender 110XS SW gone... now VW California 180 4 Motion. |
16th Mar 2011 11:48am |
