Home > Technical > 95 110 defender utility side windows?
horus1970
England 1995 Defender 110 300 Tdi HT Portofino Red
i have a 1995 110 defender utility, basicaly a hardside van with 2 windows each side, they are not in frames they are just set in rubber seals it would appear,
problem is i have broken the drivers side rear and havnt a clue where to buy a replacement piece of glass?? any help would be greatly apreciated,, its the ones with the side windows are about the same height as door glass, not the little slit type side windows if that makes sense ha
Post #637153 12th Jul 2017 2:52pm
Photos paint a thousand words.
Post #637176 12th Jul 2017 5:30pm
I don't know if glass like that was ever produced in a standard size that you could buy off the shelf. However, many years ago I fitted similar windows to a Series III and I had the glass cut by a company that built coaches, so it may be worth seeing if there's a commercial vehicle body shop near to you. Darren
Post #637177 12th Jul 2017 5:31pm
Go to your local glass merchant and they will cut you a piece of laminated glass to fit.
Post #637179 12th Jul 2017 5:47pm
horus1970
cheers lads will try that tomorow
Post #637215 12th Jul 2017 9:29pm
zsd-puma
Or do it yourself with perspex and a jigsaw, depending how pretty you want it to be.
Post #637232 12th Jul 2017 11:43pm
