![]() | Home > Maintenance & Modifications > MY14 110 Rear Brake Rattle |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3663 ![]() ![]() ![]() |
think the rear pads are held in with two split pins and an anti-rattle plate, parts are cheap and easily replaced would take less the 1 hour and should cure your rattle, might be time to do the pads as well DEFENDER 90 TDCI XS,
Gray73 Member Since: 27 Mar 2014 Location: Folkestone, Kent Posts: 12 ![]() ![]() |
Thanks for the reply. I'm not sure that will solve the issue though having read a few posts on the forum. I know the pads have some decent meat left as it's been into the dealer recently. Apparently this is a common issue on 110's that LR don't yet have a fix for!? I think perhaps I'll take it to my local garage, ask them to work their magic and see what occurs. They sorted the last 'design fault' with my fuel tank breather for £46 plus VAT including steam cleaning the fuel tank area so I'm hopeful they can come up with a fix whatever that may be....fingers crossed.
Biffas Member Since: 30 Dec 2015 Location: Surrey Posts: 122 ![]() ![]() ![]() |
lots of copper grease , mine rattled when it was new but when it gets a wear ridge on disc it should stop mine is a 2014 with 20000 miles on the clock and they rattled like mad when new but did stop.
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I wonder if they forgot to put the springs back in when they fitted the new pads.
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 ![]() ![]() ![]() |
I've had two or three 110s and they've all rattled. New springs and copper grease work for a bit.
Not putting my hearing aids in and keeping the windows up makes mine like a Rolls Royce. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17645 ![]() ![]() ![]() |
The rattle is a design feature to reassure you that the calipers haven't seized yet. When the rattle stops, you need to attend to the brakes.
Fitting stronger anti-rattle springs may help, and the usual "fix" is to run a bead of weld along the edge of the pad and then file the bead so that the pad is a good sliding fit in the caliper. Is it worth it? Probably not. Pragmatic solution, turn up the radio and ignore the rattle. |
Thanks for the tips all. I'll get myself onto Amazon when I get to work and buy myself some earplugs!! Maybe I'll call LR and advise them my complimentary set weren't in the vehicle when I got it
here's a thought, these calipers are the same design used on the TD5, they probably rattled on the TD5 too, it' just you couldn't hear them over the rest of the noise!
Annoyingly it's only started happening recently, it's just over 3 years old, circa 35k miles, and still on the first set of brake pads. Perhaps when the pads need to be changed it will go away again until they are worn. They still have meat on them because it went into LR recently and they gave me a report which included details of brake wear etc....... I'll close the window and put my earplugs on
Mine has just started rattling again because I have fitted new (genuine) pads, the old worn pads had stopped rattling.
I think that the rattle is caused by the pads bouncing up and down in the calipers. The weld solution I described above works by making the pads a better fit in the caliper slots, but a build-up of dirt and grot can have the same effect. I suspect that vehicles that work hard and in grubby conditions rattle less than the washed and polished sub-species for this reason. I have found that genuine pads are less likely to rattle that others (and also far less likely to squeal and shriek under braking, which is a more irritating but widespread problem), but I have also found that stronger anti-rattle springs can have the desired effect, the only problem with this is finding a suitable spring (this is of course the spring that fits round each retaining pin). You certainly don't want to re-use the old springs when fitting new pads, since they will have deteriorated - always use new springs. Stretching them before fitting can help and will sometimes have the deried effect. Clearly if you do fit stronger springs they mustn't be so strong that they retract the piston into the caliper, although it is extremely unlikely that it would be possible to fit a spring this strong in the space available. |
