![]() | Home > Maintenance & Modifications > Springs again... |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2464 ![]() ![]() ![]() |
I'm not sure about older Defenders but in the worse case you can fit a Disco rubber spring isolator on top of the spring. Puma 110" SW
