- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
drinkdrinkdrop
Split Charge Earth Connection | |
I'm installing a Blue Sea 7622 VSR in the battery box of our 110 and I'm wondering about how best to connect my negative terminals. The wiring diagram shows it using a bus bar
http://assets.bluesea.com/files/resources/...L-ACRs.jpg
Am I correct in thinking this setup is no different to just bridging the negative terminals on the two batteries with an earth strap (i've got some spare 35mm battery cable and terminals) so the standard defender main earth lead on the starter battery negative then a cable connecting that to the negative of the 2nd battery. Both batteries are Varta LFD90's if that makes any difference
10th Jul 2017 12:00pm |
10th Jul 2017 12:31pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
