Home > Technical > Defender td5 headlights
Page 2 of 2 <12
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Update. New switch fitted and lights now working how they should. Thankyou for all your help guys.
Post #636318 7th Jul 2017 10:29pm
zsd-puma
It's worth fitting one of the headlamp relay kits you can get. As standard the full load of the headlamps is fed through the switch, which is why they melt. The relay kits, just run a signal current through the switch and draw the main headlamp current direct from the battery - it also gives you brighter headlamps.
Post #636339 8th Jul 2017 4:42am
Page 2 of 2 <12
