Home > Puma (Tdci) > Roof rack prototype
midmaik
United States
Roof rack prototype
Here is my version of a expedition roof rack.
cheers
Maik
Post #63631 14th Mar 2011 8:25am
wobble_hd
It has a GRRR industrial look!
Love it!
Post #63636 14th Mar 2011 9:13am
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
it looks cool,
just one question, how much will it flex under load and will it then make contact with the roof, therfore would it make sence to reduce the tolerences a little more and pad the underside so it touches the paint work but spreads the weight stops any damage and still gives you the fixing points?
as you may be able to tell this is the way i was thinking of going, the only problem i had was a limited talent with metal fabrication Embarassed
unlike yourself. Thumbs Up
Post #63647 14th Mar 2011 10:16am
leeds
Interesting concept, looks well made, and very low Thumbs Up
How will the clamp system work?
Have you got some 'bolts' which will lock into the holes?
Aluminium or steel?
Weight
Ooops a list of questions
Looks like you have access to some decent metal stocks/engineering facilities
Will be interesting in how it 'performs' in the field.
Keep us updated and well done. Thumbs Up
Brendan
Post #63650 14th Mar 2011 10:32am
BigRuss
It loos well supported, interesting to see what the final product will look like.
Have you though about supporting the rack from gutter above the rear door? Russell
2011MY 110 XS USW Black
Post #63661 14th Mar 2011 11:41am
midmaik
United States
Many thanks guys for your flowers Very Happy
The material I used is 3mm steel. It is bended to a U-Form, so I had a previous version of it in Northafrica.
I had approx. 25kg load on that rack and we finished serveral hundred kilometers through dunes and 2500km over rough run ways. I couldn't observe any weak points on that rack.
I have no pics from the clamp parts, I will keep you informed. The clamp will be bolt by 6mm screws.
The weight will be about 15kg.
I think, when I reduced the distance between the rack and the roof it could produce more wind noise at higher velocities.
Maik
Post #63667 14th Mar 2011 2:14pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Looks really neat. I'm impressed!
Post #63689 14th Mar 2011 6:10pm
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
ok, how much are you going to sell them to us for, cause it looks the business, 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #63952 16th Mar 2011 5:39pm
midmaik
United States
update
Post #68372 23rd Apr 2011 5:26pm
Portafilter
Australia
freakin awesome
when you selling them!
Post #68420 24th Apr 2011 12:09am
jont
2006 Defender 90 Td5 XS CSW Santorini Black
Amazing rack - great piece of craftsmanship ... am loving the led bank of lights though - where are they from ?
Jon
Post #68427 24th Apr 2011 7:29am
midmaik
United States
@Portafilter
I'm thinking about selling, but the prive can't be under 1700 pounds. there is so much handwork inside.
@jont
thanks, the leds are from rigids industries (USA), 80 piece of high power leds, when you switch it on, you think the sun comes up Shocked
Post #68444 24th Apr 2011 10:58am
T1G UP
midmaik wrote:
update
Very well done Thumbs Up
Post #68456 24th Apr 2011 12:38pm
midmaik
United States
Thanks guys for your flowers Embarassed Here is now the final version.
Post #69162 1st May 2011 7:00am
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
VERY MAD MAX ! looks good
Post #69172 1st May 2011 8:40am
