Home > Technical > Wiper woes |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 699 |
My new ones arrived yesterday .. they have metal wheels
Click image to enlarge Click image to enlarge 2008 Defender 110 XS SW - M57N2 / 6HP28X |
30th Jun 2017 4:25pm |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
That's good to know, ordered mine from Island4x4 as well. 2010 Defender 110 Station Wagon, Santorini Black.
30th Jun 2017 5:11pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
That's good, lightningweeds must have been having a wierd nightmare and imagined it!
30th Jun 2017 6:55pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 916 |
Two weeks ish ago Matford changed the wheelboxes, the rack and the motor on mine under warranty. Took them about 4.5 hours including a Valet afterwards. I know as I was drinking all their tea and getting my monies worth out of their Wifi connection whilst waiting. |
30th Jun 2017 7:02pm |
Hope he's not been smoking his namesake 😳 4.5 hours does seem more reasonable Devon-Rover, with my Main dealer that would be over £500 labour! Chris 2010 Defender 110 Station Wagon, Santorini Black. |
30th Jun 2017 8:35pm |
Back together and not a single screw left over .. must be a first !
2nd Jul 2017 4:34pm |
All done, no screws left over! Bit of a job 9 hours+. I'm afraid it was taking so long I gave up on the photos. Thanks for all the advice and encouragement.
6th Jul 2017 2:21pm |
Good work .. very satisfying when it's all back together!
Unfortunately mine didn't stay together for very long as decided to try and reduce the heat inside in the few days of summer that we have. All the headlining is currently out and dynamat is being applied everywhere. Hopefully it will stop it being quite so hot! 2008 Defender 110 XS SW - M57N2 / 6HP28X |
7th Jul 2017 8:14am |
If you want to reduce heat build up, then you need to install some closed cell foam over the Dynamat. The latter is really just to stop the panels resonating.
I've recently done mine: Click image to enlarge Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
7th Jul 2017 8:21am |
Good tip .. thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X
9th Jul 2017 7:04pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
I can confirm the genuine wheel boxes are and have always been made of steel.
Ask me how I know.... Click image to enlarge Click image to enlarge Click image to enlarge After not using the wipers for a good few weeks, the o/s one decided to seize up, and also managed to destroy the park switch in the process, great.. Luckily I had a spare motor with what I thought had a good switch, but no! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
15th Jul 2017 8:52am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Although my wipers are still working they jammed the other day on intermittent.
I managed to free them up in the end but imo is a warning to check them out. What likely caused them to jam up, I'm guessing the wiper wheel boxes themselves perhaps a gear but happened in dry weather after little use for a while. Shall I replace the wiper wheel boxes? As far as I'm aware the park switch, the motor etc are all fine. I'm not sure how well lubed they are currently either, I haven't touched them before but there is a bit of corrosion on the outside regarding the spindle. I've also got a little puller, as I'm pretty sure they wouldn't just come off as I tried. $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
4th Jun 2018 9:29pm |
