Home > eBay & Bargain Spots > TD5 full size intercoolers
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Seems like a bargain, no idea on quality though:
http://www.ebay.co.uk/itm/Land-Rover-Defen...1438.l2649 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #635791 5th Jul 2017 5:16pm
mk1collector
The welds look like they gave them to an apprentice to practice. Ray
My build thread
Post #635799 5th Jul 2017 5:56pm
ericvv
Look at pic 12/12 of the eBay item. I have little confidence in items if they can not write the description in English even remotely close to correct. "Bar & palte", "smooter air flow", not only those two, just read the entire description. Rolling Eyes
You better hope that their welding skills are better than their absent spell check. Laughing
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #635801 5th Jul 2017 6:21pm
Kit
They usually aren't too bad, a friend of mine has one on his turbo e36 m3 and its stood up to everything so far? 1993 200 Tdi 90 CSW
Post #635816 5th Jul 2017 7:28pm
bankz5152
£200? Worth a punt. May work, may explode. Be interesting to see results!
Post #635909 6th Jul 2017 8:36am
smb
^^As previously said, that welding quality is very suspect. And that is what you can see. Try and imagine what you can't see!! Factor in the time to fit and remove if theres a problem and the hassle and you probably won't be far off the cost of an Allisport one or similar. I wonder what they are pressure tested to?
Post #635937 6th Jul 2017 12:28pm
