Home > Td5 > De-Cat Query
Rusty380
De-Cat Query
Hi There,
Recently picked up my defender which still has an original exhaust on it!
Couple of questions really, if I replace the rear silencer for a straight through and de-cat will that get a nice tone or is a full manifold back required?
Also is a remap required after replacing he exhaust? It currently has an economy remap on iT, so I will I knacker this up as a result?
Not sure if it's the same on these as it is with tempermantel jap crap!
Post #635249 3rd Jul 2017 8:36am
bob neville
I have a decat and a very small cherry bomb rear box on my TD5.
It gives a lovely sound without any droning.
No remap on mine and it is fine.
2013 Defender 90 CSW - sold
Post #635256 3rd Jul 2017 9:23am
rustandoil
I put a De-cat pipe and removed the rear silencer on my 110 but i left the rearmost silencer in place, sounds ok and not too loud Very Happy
Post #635259 3rd Jul 2017 9:40am
bankz5152
The manifold can be left standard. De-cat and straight thru can be fitted at any time at any stage of tune. You'll get a nice bark from it! It's not too loud but long journeys on the motorway do become a bit more tiring is the only downside! Best to keep the rear most silencer fitted though, removing it does make it sound awesome but it is loud haha
Keep the original cat though as you may need it for the MOT, neither of my TD5s have needed it but you never know!
Post #635261 3rd Jul 2017 9:57am
Rusty380
Lovely, Thanks All!
I'll get these ordered then, seem good enough quality. I'll hang fire on the replacing the backbox until I see how it sounds with just these added.
Silencer Removal Pipe
http://www.terrafirma4x4store.co.uk/TF_exhaust/TF554_silencerpipe
De-Cat Pipe
https://www.flatdoguk.com/-discovery~264
Post #635274 3rd Jul 2017 11:04am
bankz5152
The TF unit is what I had on my old 90, no complaints! Stainless De-cat too for £66 thats good!
Post #635276 3rd Jul 2017 11:07am
miker
Mine never had a cat due to being too old, I have now got a straight thru centre as well. Leaving the rear box in, I think it would get a bit much without it!
I don't notice much of an increase in cabin noise on the motorway. Can hear it under throttle though. I think the extra length of a 110 helps here, the end of the exhaust is a long way from my ears!
My obligatory video link:
Post #635278 3rd Jul 2017 11:10am
Hufflepuff
Mine has the cat, with a full stainless Alive setup with mid-box delete, and its far too quiet, I can't really tell a difference to standard Sad
Post #635291 3rd Jul 2017 12:04pm
roel
I first removed the middle silencer from my 2003 90 td5. That gave already a better sound. Later when I was able to remove the nuts from the turbo so I could get away with the Cat. That really made a difference. Nice turbo wistle etc. (when the rear door is open) Twisted Evil
I still have the rear silencer in place.
It is tuned and hardly smokes under load. Roel
2003 90 Td5 (2009-now)
Post #635386 3rd Jul 2017 7:19pm
lightning
I removed the CAT from my 2005 TD5.
It made the turbo spool up quicker, pretty much eliminating the lag when you put your foot on the gas.
Sadly there was also a tiresome droning at 2500-3000rpm on the motorway and after 12 months l fitted a new CAT pipe. It's quieter now but the "TD5 lag" is back.
Since then l've had a remap which had made the engine quieter at motorway speeds (?) So l may try again with the decat pipe.
Post #635414 3rd Jul 2017 8:39pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I had a centre silencer removal pipe on my first Td5, (no cat, too early but a decent re-map,) it made a great sound but not too loud, however, in preparation for a long trip down to Spain, I refitted the centre box to minimise the amount of droning noise at speed, as soon as I set off I realised it was a mistake and regretted it, the noise was reduced a little but the performance was significantly diminished.
It's surprising how quickly you get used to a performance tweak and then take it for granted so it seems a huge loss without it, first thing I did on my return was to remove the centre box again, the reduction of back pressure makes the turbo spool up a whole lot quicker.
Post #635452 3rd Jul 2017 10:10pm
JWL
Same results as Clive, my 110 has a stage 1 map and when first done the exhaust system was standard. I really noticed an improovement when I took the middle box out but when I replaced the front pipe for an earlier model spec without the cat it transformed the motor, it was like getting a new map on it. Every year I used to put the original downpipe back on for the MoT, it's a good friend that tests it and I didn't want to be the one whose motor was on the ramp when the man from VOSA turned up when he's turning a blind eye to the fact that the cat is missing. The day or two running the 110 with the cat back on was painfull, there was a huge difference in the performance so before I put the cat back on the following year I slit it open with the grinder, took the innards out and welded it back up empty so it now complies with the visual check. The can is completely empty and has quietened the booming that could be a little wearing on long motorway trips.
Post #635462 3rd Jul 2017 10:55pm
Rusty380
Roel that sounds bang on!
Thanks for all the feed back, de-cat and centre silencer removal it is.
It pulls lovely due to the remap thats on it so hoping for a little more would be a bonus!
Droning doesnt bother me too much if im honest, used to it from decatted jap crap with endless popping and banging Laughing
Post #635550 4th Jul 2017 2:33pm
lightning
The day or two running the 110 with the cat back on was painfull, there was a huge difference in the performance so before I put the cat back on the following year I slit it open with the grinder, took the innards out and welded it back up empty so it now complies with the visual check. The can is completely empty and has quietened the booming that could be a little wearing on long motorway trips.[/quote]
Yep, l found the 110 performed better without the CAT but the booming/droning got to me on longer motorway trips.
l don't have the skills to strip out the CAT and close up the casing though.
Were you running without the centre box as well as CAT removal?
Post #635822 5th Jul 2017 7:48pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I'll try and get a clip of my td5 with de cat and straight centre pipe sounds the nuts 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #635865 5th Jul 2017 9:52pm
