![]() | Home > Technical > Connecting to OBD socket |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Yes it does support OBDII can-bus. Always have the ignition off when connecting any OBDII plug as the scan tool will get power with the ignition off. I know that with the scangauge when I unplug it then re plug it, it takes a couple of minutes to power up. Where as the nanocom, alientech remap box and IDS system I have power up straight away on connecting. What make is the scan tool? Is it can-bus complient? |
Did you check the fuse? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
BRDM Driver Member Since: 10 Mar 2011 Location: dorset Posts: 25 ![]() |
It's an OBDlink scan tool that connects to your laptop. Basically a CAN to USB coverter.
Certainly works on my 2009 GTR. |
