![]() | Home > Maintenance & Modifications > Ford Ranger 3.2 Conversion into a 110 Puma Defender Advice |
Drover Member Since: 27 May 2011 Location: Central Coast NSW Posts: 53 ![]() ![]() |
Bell Auto Services (BAS) have done the conversion and should be able to supply the wiring loom to match it all up so you can still use your original dash, ABS, TC and other electricals.
BAS were selling a kit that included motor/box/electricals for the UK customers but from memory it was pretty exy ! Another company that are selling 3.2L converted Defenders is Icon, may be contact them. http://www.defendericon.com/conversions.php |
chewy7 Member Since: 19 May 2013 Location: Brisbane, Australia Posts: 34 ![]() ![]() |
Drover, I just replied to your topic on AULRO, haha!
I will contact BAS and see what they say, as i only need the harness. |
Hey Chewy,
The extension housing from the PUMA's MT82 will bolt straight onto the MT85 and then onto the LT230 transfer case. The question on this end of the box is will the output shaft on the MT85 match the LT230 ? or do you use the output shatf from the MT82 and does that fit the MT85? |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
The 3.2 ranger conversion hasn't been done and needs around 10k of development before it will be done unless someone is willing to spend that to start with I doubt it will be being done any time soon ?
It's a different opera ting system to the transit 3.2 Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Mt85 and 82 are the same box apart from the bell housing 2015 2.2 tdci hardtop xs
guch Member Since: 20 Jun 2017 Location: kenya Posts: 4 ![]() ![]() ![]() |
Hi Big Steve, been reading your replies to the forum, and noticed that you had already done the conversion. I have found myself a salvage 3.2 ranger, next job is to swap with my 2.4. I would like to carry the automatic transmission from the ranger into the defender, have you tried that? (the salvage vehicle is an automatic)
Hoping i can put on the defenders transfer box. Any suggestions on how you went about the wiring, so that the original instrument cluster can work? Thanks in advance Guch |
Hi as said in previouse posts
The ranger 3.2 engine is different ecu therefore has not been cracked and has not been made to run yet Company's like je engineering have got the engine on a standalone ecu which is not right as the engine is far better with its own ecu to to run it They also offer the gearbox conversion I am looking into this myself for my 3.2 but need a complete ranger for development and then tbh we will probly look into getting the engine to run standalone also Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Ive located a salvage Ranger, working on a deal with the guy at the moment, he is looking for too much money compared to the costs you have given.
Let me PM you. Guch |
