Home > Australia & New Zealand > External RolL CAGES
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
External RolL CAGES
ANYONE KNOW IF EXTERNAL ROLL CAGES ARE OK ON A 110 IN OZ?
Post #632300 19th Jun 2017 5:29pm
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
The rules changed when they introduced the NCOP in 2011 (about)
Until then it was state dependent, ie Qld was ok, WA not so much
The NCOP has standardised it a lot more (there are still a few differences) but roll cages were more restricted than they were previously. (Especially internal 6 point ones)
LK8 / LK9 are the sections og NCOP related to this now. (Google should get you the PDF's)
A full external cage, or an internal hoop and then external cage may still be ok. You would need to check the docs, and I would also suggest speak to an approved person who can sign them off. 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #632361 19th Jun 2017 10:07pm
itolond
Appreciated,
This will most likely be Victoria or Tasmania. Internal roll cage come under the same rules as well?
Post #632387 20th Jun 2017 4:57am
psimpson7
yeah, sure are. NCOP stands for 'National code of practice' and it is fairly standardized. There are some differences but the main points are similar I believe. 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #632389 20th Jun 2017 5:53am
