Home > Maintenance & Modifications > Chassis Rails Silted |
m666blp Member Since: 22 Jan 2015 Location: cumbria Posts: 68 |
Take a look at the first 10 mins of this you tube vid regarding chassis cleaning .
17th Jun 2017 12:16pm |
I also thought of using a drain cleaning nozzle for a pressure washer to get right in to a chassis . You will need to protect with cavity wax after it is dry. |
17th Jun 2017 12:21pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
i tried doing that but its almost impossible. It kept getting hung up on internal brackets etc within the rails. Pointless exercise.
18th Jun 2017 3:29pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1766 |
I jacked the backup really high, and used some 8mm tube adapted to a garden hose and ran that through - came out of the front jacking plugs, the sheer quantity of red Spanish dust that came out was amazing for a 18month old car. left to dry for a week then pickled in Dinitrol.
good luck! |
18th Jun 2017 6:58pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2266 |
Thanks. I did a bit of googling after posting this and have ordered a drain jetter for my karcher - worth a trym but if no luck I will rig up a small bore tube to the hosepipe
Cheers |
19th Jun 2017 9:23am |
Wheel Member Since: 29 May 2014 Location: Essex Posts: 233 |
I washed out a couple of chassis on older models a few years ago and used normal hose on some easily accessed areas and adaptors to take my pressure washer fittings to 6mm pneumatic line to access the more difficult/smaller/awkward areas.
It worked a treat but was fairly stripped down so getting at it was definitely easier than on a fully built up vehicle as lifted it around with an engine hoist and on ramps etc |
19th Jun 2017 10:03am |
