![]() | Home > Technical > 300tdi (1998) coolant loss and overheating |
If you've got bubbling in the expansion tank and coolant loss then the obvious concern is a blown head gasket. To be honest, running it for 20 minutes with the gauge in the red won't have done it any favours either and it's entirely likely that that has done more damage.
Don't know how far 'back to base' is. If it's a mile or two then you might get away with it, but you may find that it overheats again very quickly. If you can get access to a gas sniffer, you may be able to confirm or discount a head gasket problem. Being towed back to Blighty is looking quite probable, though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Jonathan111 Member Since: 22 Jan 2015 Location: London Posts: 67 ![]() ![]() |
Hi - thanks for this, the coolant system was pressure tested a few weeks ago, and found to be OK, but I guess that was a few weeks back...
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
You can try some radweld, barr seal or similar in it. I know even mentioning such products will rip open a hornets nest, but the fact is in some cases they do work and are nothing like the messy clog prone gunk they used to be. I've even seen them rectify a minor head gasket leak, clearly it's not a permanent fix, but it might get you home.
If it's airlock then running with it is bad, as the coolant isn't circulating. |
Thanks - appreciate these thoughts - I am trying not to think that it might be a torched head - I mean is that an automatic thing every time the temp gauge goes to red? Anyway, the engine is under warranty and looks like the beast will have to suffer the retreat of shame back up to England on a recovery vehicle. The insurance people are trying to find local specialists to give a verdict in Provence - remarkably few! I'm working so can't do anything.
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
have you checked P gasket for leaks? My 109 thread
my youtube channel |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5236 ![]() ![]() |
Sounds to me that you have still got air in the system, Id run a hose pipe through the full lot with all the bleeder nipples running and then give it a good bleed with in an inch of its life. I had to do with the K series engine I did the head gasket on last year. Took some bleeding mind but I got there, also what was the cause of the head going? was that sorted out? I find some people just fix the head gasket but never really look at why it failed in the 1st place. My advice really for you to make it home safe, is keep a ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
thanks alot, appreciate the advice, its being transported back, so will have a good look over it once its back at base - the engine was completely overhauled 2kmiles back and its still under warranty, so no idea what has gone wrong....will find out soon enough!
