![]() | Home > In Car Electronics > 12V feed for 85W fridge |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 ![]() ![]() ![]() |
I'm afraid a dedicated and fuse protected supply is your best bet.
It's an opportunity to put in battery protection too. My only other input is to ensure you put a decent gland on the battery box when feeding the conduit. I recently saw a wire cut through and welded to the metal when vibration had cut through the rubber grommet. |
Emile Member Since: 17 Jun 2016 Location: Inside 110 Posts: 15 ![]() ![]() ![]() |
A direct feed from the battery has become my choice. Got some 2.5Qmm wire and a Kemo M148A Battery Guard. The only thing I have to attack now is the connection with the fridge as I take it out and put it back in every day on the trips we do. Avoiding sigaret lighter plugs there seem to be not so many options. Any advice on good quality 12V plugs? TIA
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
This would work.
http://www.defender2.net/forum/topic20319.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 ![]() ![]() ![]() |
For my fridge, I use the Hella plug setup.
Does not work loose, avoiding a short curcuit in the plug and potentially frying the fridge. Can also be made 'water resistant'... ![]() ![]() Douglas Adams 2012 2.2 Puma |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 ![]() ![]() ![]() |
Anderson powerpole are pretty standard for 12V at a reasonable current.
Speakon are great, and I plan to use a couple for a similar purpose. They're not "rated" for DC though, and it is a non standard use of the outlet. |
