Home > Maintenance & Modifications > Dampers and polybush
bear100
Hi all
I am looking into changing the dampers and maybe fitting a polybush kit to my 110 utility, has anyone fitted the polybush kits? And did they make much difference to the ride? Are there any other makes better?
She has done 50K now and its starting to feel a bit sloppy Shocked
Any recommendations of dampers? I am after something to improve comfort and ride.
Thumbs Up Thumbs Up Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #631189 13th Jun 2017 9:43pm
I've tried Polys, not a fan at all.
Stick to genuine. Thumbs Up NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #631192 13th Jun 2017 9:47pm
bear100
Oh Shocked why is that? Are they to stiff? 2016 Range Rover Autobiography 4.4 TDV8
Post #631194 13th Jun 2017 9:51pm
Dobby
+1 for genuine bushes from me too. Might be more of a pain to remove &a fit, but well
Worth it compared to the poly alternatives, IMHO.
Post #631195 13th Jun 2017 9:52pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
I have been running the Polybush orange (Dynamic) for over a year now. (bought from YRM with the graded stainless hardware). I am very happy with the ride, not harsh at all, less of a vague feel on the tarmac. I wouldn't hesitate to recommend them.
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #631230 14th Jun 2017 3:56am
zsd-puma
Big problem with poly is although it's stiffer, cheaper to make and longer lasting, it's also far less effective at isolating noise and vibration, which is why car manufacturers do not use it. Whether that extra noise and vibration make mulch real difference on a defender is another issue. It's noticeable on my mini.
Post #631265 14th Jun 2017 10:27am
proloFort
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
I can not speak for Defender but when I use poly on a gearbox mount for another vehicle I renovate it was a big mistake. The noise and vibration were not acceptable and finally I returned to rubbing ones. More work to do and must change again in future but better.
Post #631267 14th Jun 2017 10:34am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Poly on Fiesta for small road competition use were super. For offroad use in Defender not.
In Fiesta, there were barely any movement in very hard suspension when used on road. With Defender and offroad use, it is quite opposite - long springs, big movement of axles. Some cheap poly were just pulled out of their fixing - they literally flowed out. Higher quality are quite expensive, comparing to genuine LR bushes.
On Discovery 2 with 200 000km I have changed first 2 original bushes. For genuine. I hope, they will survive for long time. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #631301 14th Jun 2017 1:00pm
bear100
Suprised me! I thought the poly bush way was superior Shocked ok Genuine is the way forward.
What dampers are rated the best for comfort and quality? 2016 Range Rover Autobiography 4.4 TDV8
Post #631338 14th Jun 2017 3:38pm
I'm quite happy with genuine, that being said I've not tried others.
Bilstein B6 has good reviews. Thumbs Up NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #631339 14th Jun 2017 3:43pm
sako243
I've not tried polybushes in the suspension components but done it on a panhard rod and was utter ****.
The fight with genuine ones is worth it, mine were on there 160k miles and 22 years. They were knackered when they came off though. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #631341 14th Jun 2017 3:56pm
CDN38
I don't think all poly bushes are the same. I know there are several brands out there, and like most things, if you buy cheap, you get cheap. Genuine Polybush, and SuperPro bushes are good quality, I have yet to hear of any issues with failure or ride quality, from those I know with them fitted. I have heard of failure and ride quality issues with other brands.
Allmakes used to cary Polybush, now they are selling their own brand. In my mind, dropping a brand name product to introduce the "house brand" usually is done with profit as motivation, and rarely is of the same quality. it's a Landrover thing...
Post #631345 14th Jun 2017 4:34pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
Superpro lasted 20k miles on my 90 and were completely shot. Used only for laning and road use I was very disappointed.
Post #631372 14th Jun 2017 5:56pm
proloFort
Bilstein B6 with ride control is good. Comfort setting for off-road and then a harder setting for road. Woeks very good. All from button in cockpit. For me this came with vehicle so can not compare to original but my friend who had same defender before said to me very big improvement.
Post #631386 14th Jun 2017 7:07pm
JeremyJ
I use Blue Polybushes on mine and rate them, have had on several Defenders and Classic Range Rovers with no issues or change to NVH
Post #631387 14th Jun 2017 7:08pm
