![]() | Home > Td5 > Defender td5 2001 interior light permanently on |
chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119 ![]() ![]() |
So I wired in some footwell lights for the defender using the purple/blue wire and the purple brown wire on the right hand side of the windscreen.
It was working great going on and off when ignition on and off and also when door opened. However the interior lights won't go off at all now on all the time. When plugged in with nanocom to operate the lights with that it just gets brighter but won't go off I have tried a different 10as and also it appears that there is a permanent 4v supply to the wire whereas there wasn't before ? Was 0v and then when door opened it was 12v Any ideas ??? |
Tried a different 10as and there is still a permanent 4v live regardless of whether there is 10as plugged in or not ? Also regardless of door opened or ignition on ...
Where could it be getting permanent 4v supply? |
Did you check the door sensors? They are not the quality I expected them to be.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Checked the door switches with nanocom they work fine... also tried a different 10as box still outputting a 4v supply ... can't find that on the diagram where it could be getting that from ?
interior light works with fuse + feed and switch battery neg with gray plug removed from 10AS and lamp removed from interior light test purple/white wire to battery neg with multimeter for short to ground
