Home > Technical > Optima red top battery revival?
I've got a couple of optima's in the garage. They were almost "new" a few years back, only had light use before they were removed from the genset they were on.
They've sat on my shelf for a while and are now flat as a pancake.
So what's the best way to revive and recharge them? I've not got any fangled chargers (maybe I need one?) but have a decent bench PSU at work (adustable up to about 30v, and 4 or 5 amps, nothing mega) ... can I just connect up and trickle charge it with 13.4v (or whatever anyone else can suggest?) for a day or 3 and see if it will bring them back to life?
Suggestions on a postcard please.. Thumbs Up Whistle
Post #631178 13th Jun 2017 8:08pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
This might be just what your after? Wink
https://www.optimabatteries.com/en-us/supp...ed-battery 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #631190 13th Jun 2017 8:45pm
bear100
I bought a C Tek charger for my standard defender battery, in was going to replace it but after a discussion on this forum i bought the charger, its has a recon mode and took about 24hrs to complete Shocked Shocked wow was i amazed the battery has never been so good!! It works wonders, many people say it recons the battery better than when it was new and i can totally believe it, it also has a trickle charge function.
Well worth the £27 price tag Thumbs Up Thumbs Up
They also sell them at Halfords 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #631193 13th Jun 2017 8:51pm
roel
If the battery is completely flat most chargers will not start charging the battery. I think that is a safety feature.
My Ctek has also a supply function and I use that for some minutes to give it a little charge and then change over to normal charge or revive depending on the battery.
I have a feeling that the revive function doesn't really work on the Optima batteries but works very well on lead acid batteries and yes that takes a long time but with sometimes amazing results.
Other times however a battrey is dead and even an Ctek can bring it back to life. Roel
2003 90 Td5 (2009-now)
Post #631239 14th Jun 2017 5:53am
V8GPC
Another vote for a Ctek charger. My 50th doesn't get used everyday; and i had the battery go flat a couple of times on me; usually when you wanted to take the 50th out. I thought maybe it was just the battery that was dead. I had charged it with a PSU type charger in the past.
Instead i decided to buy a "Ctek mxs 5.0" mainly to keep it on a trickle charge; and did the regen cycle on the first connection.
Although always on trickle charge; the engine turns over much faster than before - every time i start it; and recently i took it away for the week, and left the charger at home. Never missed a beat and started every day like you'd expect. (even on the battery I though was dead.)
it goes through various modes; and is often rebranded and sold with top spec sports cars as an expensive option.
£60 ish but sound like those Optima batteriies would be restored - which would cost you more to replace.
Post #631240 14th Jun 2017 6:08am
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
What I do is connect another battery to the charger as well. It fools the charger and it starts supplying a charge. V8 90...WIP
Post #631241 14th Jun 2017 6:13am
Balvaig
+1 for Ctec charger.
I have a 12 year old battery still going strong, despite irregular use.
Post #631245 14th Jun 2017 7:11am
1967jester
Another +1 for C-Tek. Using the MSX-10, great bit of kit
Post #631291 14th Jun 2017 11:24am
Cool, thanks all. Think I'll be getting one soon. I take it the ctek can be used just as a trickle charger for normal lead acid batteries as well.
Looks good. Won't get one dfrom Halfrauds though... £99! Shocked
Post #631295 14th Jun 2017 11:36am
Mdm
Ctek or equivalent is good
You will need a min of 8 amp spec and more is better around 12 amps max if memory Serves me
You need to trickle charge it 1sr and then try a recondition on it ,if it won't charge try it with a recon,it will get hot so a well vented area is a good idea in case f fumes or it going pop.
Post #631302 14th Jun 2017 12:02pm
