Home > Maintenance & Modifications > Wiring rear work lights - help needed
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Sorry if this has been covered before (please post link if it has) I did a search and couldn't find what I need to know.... Confused
I want to wire up some new work lights to my 2010 HT 90 I'm in need of some advice on how to do this please!
This is what I'm wiring up 2x 12w LED 12V lights towards the top of both the rear panels above the rear windows
http://www.ebay.co.uk/itm/4X-12W-LED-Work-...SwOdpXypMR
I'd like to wire them in to a switch on the dash I have a few spare/blank sockets to choose from in the cluster above the radio. Is there a genuine LR work light switch I can purchase for the job?
I'd like to switch them on/off regardless of the ignition being on.
Obviously I'm going to need to drill through the rear panel to run the work light wire in to each side I'm guessing a grommet in the hole with the wire running through it? Hate drilling holes in my truck.... Big Cry
So how and where would I run the wires to or from? Do I need a relay or an inline fuse? Where can I pick the power up from? Is there anything permanently live at the rear of my truck that is already switched at the front on the dash?
Any advice would be helpful Thumbs Up 2010 Defender 90 HT
The longer I live..... The better I was!
Post #631130 13th Jun 2017 6:29pm
Butchers Boy
Shame this thread is dead!
http://www.defender2.net/forum/topic18978.html 2010 Defender 90 HT
Post #631160 13th Jun 2017 8:06pm
For an LED light of that wattage you don't need a relay as long as you choose a suitably rated switch. You could probably adapt an OE switch but you'd either have to put up with an odd graphic on it or faff around modding a blank.
There are lots of ways to do the wirings so this is just one idea: in the off-side rear light cluster is a spare purple wire that's permanently live. It's fused at 10 amps, IIRC. Install your work lights and earth them locally. Run a pair of wires from the back light cluster to wherever you want the switch in the front. Connect one end to the purple wire and the other to the live on the light and you're done.
Getting the wires to the front can either be done around the edge of the roof trim and down the A pillar or out of the bottom of the light cluster, along the chassis to eh engine bay and then up and through the bulkhead.
Installing the lights can be exactly as you describe. When I installed mine I used a tight fitting rubber grommet but a cable gland would work too, if you've got the space behind the light.
I added a bit more control to mine with a couple of relays that means it comes on automatically if the reverse light and side lights are on. An on-off-on switch allows me to also turn it on independently.
 Darren
Post #631169 13th Jun 2017 8:40pm
Butchers Boy
Thanks LandRoverAnorak for taking the time to write all that for me it's really helpful, I've now got some idea of how I'm going to wire these up Thumbs Up Thumbs Up 2010 Defender 90 HT
Post #631305 14th Jun 2017 1:08pm
Butchers Boy
Anybody found a suitable OE switch or adapted one to look like a rear work light switch for a Puma?? 2010 Defender 90 HT
Post #631309 14th Jun 2017 1:27pm
Now that I think about it, somebody was selling some OE-looking switches with a worklight graphic on here recently. I think they were imported from Aus and cost around £30 each. I'm pretty sure that they all went but it does mean that they are available. Darren
Post #631315 14th Jun 2017 1:50pm
Butchers Boy
Where they these??
http://www.expeditioncentre.com.au/auxilia...02-onwards 2010 Defender 90 HT
Post #631318 14th Jun 2017 1:58pm
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
I've done this...
http://www.defender2.net/forum/topic42402.html
http://www.defender2.net/forum/topic53098.html
Hope it helps...
Will try find pics of my worklight & rear powerpoint install... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #631319 14th Jun 2017 2:01pm
stigomery
United Kingdom 2004 Defender 90 Td5 HT Belize Green
I took a feed from an additional fuse board and a couple of switches off flea bay... may not be OEM but I'm happy with them.
Post #631332 14th Jun 2017 2:37pm
Butchers Boy wrote:
Where they these??
Yeah, they're the ones. Darren
Post #631333 14th Jun 2017 2:50pm
