![]() | Home > In Car Electronics > Advice please, installing a sub to standard XS alpine radio |
Can you not just use the remote wire on the back of the headunit? If you have no other ice I can't see why it would be used already. Ray
Jimbob Member Since: 17 Mar 2011 Location: Gower Posts: 68 ![]() ![]() ![]() |
There wasn't one there weirdly! The blue/white wire which is amp remote/aerial raise according to the schematic was only going into the head unit in the block connector, no loose end or other connection there, I can only presume it's part of the factory wiring, and I'd have to tap into it which there wasn't enough room to do so? 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader 2015 Defender XS Hard Top (awaiting delivery 😄) |
What do you mean by tap into it? The wire should come out of the plug in the back of the headunit and maybe run into a multi plug then usually out the other side to nothing. Ray
Yeah for some reason it goes into the block but doesn't come back out? There's no loose end to connect to like normal
![]() 1990 200tdi defender off roader 2015 Defender XS Hard Top (awaiting delivery 😄) |
If it goes into the block then just cut it and put a terminal on. Ray
It's just suddenly dawned on me why it's connected, would there be the plug under the cubby box for the extra Sub option? I thought this wasn't available on the 90 only the 110 or could it be there? I'll check when I have chance 2009 Defender County Hard Top (gone 😞)
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 156 ![]() ![]() |
No plug in my MY14 90 XS so had to wire from scratch. Cheers, Guy.
